OP3 on EE for integrated wifi calling
  1. Pot Noodle Ice Cream Sandwich Oct 6, 2016
  2. SimonRam Lollipop Oct 6, 2016
    SimonRam, Oct 6, 2016 :
    Only if you use the community build apparently.
    Pot Noodle likes this.
  3. blueweasley Cupcake Oct 7, 2016
  4. SimonRam Lollipop Oct 7, 2016
    SimonRam, Oct 7, 2016 :
    EE don't support the oneplus currently, I think they only do it for the phones they sell
  5. EABowden Honeycomb Oct 8, 2016
    EABowden, Oct 8, 2016 :
    They say they only do it for the phones they sell but VoLTE and wifi calling are supposedly standard in Marshmallow which is why out of the box Galaxy S7s bought online will work.
    Given than the OP3 runs marshmallow it would be a disappointment if it won't do wifi calling. I'll experiment when it comes but can always use TuGo in the meantime.
  6. SimonRam Lollipop Oct 8, 2016
    SimonRam, Oct 8, 2016 :
    True, they do sell the S7's though which is probably why they work. (already set up in the system), my OP3 doesn't yet.
    Haven't looked at TuGo as yet.
  7. EABowden Honeycomb Oct 17, 2016
    EABowden, Oct 17, 2016 :
    I've got my phone and it is unlocked. All I need now is an EE sim to test out wifi calling. How long before the beta (community) build goes OTA? I'm not wildly keen about being a tester
  8. biomulv Honeycomb Oct 20, 2016
    biomulv, Oct 20, 2016 :
    So, it's it just EE that volte works with in the UK?
    As well as inbuilt WiFi calling.?
  9. EABowden Honeycomb Nov 1, 2016
    EABowden, Nov 1, 2016 :
    Hi again
    So I have my EE sim today and as expected if I go into setting and search wifi calling (I can't find this anywhere in the settings menu) and turn it on, nothing happens - in fact if I search it again it has switched itself off. I'm on OTA build 3.2.7 so should I wait for the next OTA or flash the phone to the community build which you say will allow me the vital wifi calling? How long does it take and are there any disadvantages at all of doing so?
    Cheers in advance
    Ed
  10. simonone Honeycomb Nov 1, 2016
    simonone, Nov 1, 2016 :
    I only noticed the VoLTE option after flashing the community build. When I selected it, I almost immediately received a text from EE saying that wifi calling had been set up. I realise that VoLTE and wifi calling are not the same thing (but related). Just reporting what I did and what happened. Screenshots show the option, the text, and the VoLTE indicator. And both wifi and VoLTE calling do seem to be working for me.
    remedy likes this.
  11. EABowden Honeycomb Nov 1, 2016
    Thanks - is it a simple process to change to the beta build? The download instruction talks about having Oxygen recovery and the correct 'adb files' installed. I have no idea what they even are!
  12. simonone Honeycomb Nov 1, 2016
    It's not hard, as long as you follow instructions carefully. I'm very familiar with it on other phones but had done nothing similar on this phone, so I was very careful.
    Instructions for downloading and installing the adb and fastboot programs are in many places, but I would suggest looking at this thread specifically about the OP3 - the third post has the relevant bit on adb/fastboot : http://forum.xda-developers.com/oneplus-3/how-to/oneplus-3-how-to-unlock-bootloader-t3398733
    Once you have adb/fastboot installed on your computer, use the official download page for guidance and for downloading the ROM itself (link at bottom of page): http://downloads.oneplus.net/oneplus-3/oneplus_3_oxygenos_3.5.5_community_build/
    Then I suggest the very clear instructions for installation using stock recovery (which is what you have) here: https://forums.oneplus.net/threads/...ty-beta-with-stock-or-custom-recovery.467808/
    Only one thing that might be confusing. When it says enter the following command : adb sideload <filename> you have to replace <filename> with the actual name of the ROM file you downloaded (and without the <>)
    SimonRam likes this.
  13. biohazardhc Ice Cream Sandwich Nov 10, 2016
    biohazardhc, Nov 10, 2016 :
    I'm on EE monthly plan and no VoLTE, 4G calling or wifi calling.... I'm on community build 3.5.5...
  14. biomulv Honeycomb Nov 11, 2016
    biomulv, Nov 11, 2016 :
    That's concerning. I am thinking about a change to EE for WiFi calling.
    Did you call them and ask it to be activated?
  15. stephenboyo KitKat Nov 11, 2016
    stephenboyo, Nov 11, 2016 :
    I'm on EE and I have VoLTE Option. I was informed via a text message from EE
  16. biohazardhc Ice Cream Sandwich Nov 11, 2016
    biohazardhc, Nov 11, 2016 :
    Yes... and they say that op3 isn't on the list of the devices ....
    biomulv likes this.
  17. biohazardhc Ice Cream Sandwich Nov 11, 2016
    I have that option on the phone.... but Unfortunately don't work....
  18. biohazardhc Ice Cream Sandwich Nov 12, 2016
    biohazardhc, Nov 12, 2016 :
    But today I receive a text from EE saying welcome to wifi calling
    #38
    remedy likes this.
  19. thesirg1 Cupcake Nov 14, 2016
    thesirg1, Nov 14, 2016 :
    are the oneplus 3s unlocked as soon as you use tham?
    ive just bought one from )2 and bought it outright
    EE sim in and i find data browsing the internet is rubbish speed
    #39
  20. EABowden Honeycomb Nov 14, 2016
    EABowden, Nov 14, 2016 :
    Yes they're unlocked. I'm getting nearly 80mb download speed from the EE sim
    #40
