35
[OP3/OP3T] Mental Support Group for Flashaholics 2.0
  1. luigimario The Lab - OnePlus 6T Reviewer Jun 16, 2017
    luigimario, Jun 16, 2017 :
    Thanks for the response, I appreciate it! I thought that might be the case, oh well. Just another motivation to switch to a custom ROM!!!
    theshinybeast likes this.
  2. theshinybeast Lollipop Jun 28, 2017
    theshinybeast, Jun 28, 2017 :
    New VertexOS is up and is as usual really, really good. This is now the Darkobas of the OP3 for me, my go to ROM. Here Enjoy, whoever is out there.:rolleyes:
    Dhiren Velari and luigimario like this.
  3. theshinybeast Lollipop Jun 28, 2017
  4. luigimario The Lab - OnePlus 6T Reviewer Jun 28, 2017
    luigimario, Jun 28, 2017 :
    I'm getting very close to just breaking down and shelling out $9 for Titanium Pro. I like the OOS Beta but I haven't taken the last 2 updates since they got rid of proximity wake. Does Vertex have this feature? And do you need a custom kernel or just use whatever it comes with?
  5. theshinybeast Lollipop Jun 28, 2017
    Titanium is well worth the money if you're flashing ROMs .
    Yes.
    VertexOS comes with Render kernel built in and there is absolutely no need to flash another one.
    Check out the XDA thread for all your needs. I highly recommend it.
  6. luigimario The Lab - OnePlus 6T Reviewer Jun 28, 2017
    Cheers, appreciate the info. I'll have to add Vertex to the list of ROMs to try. Any idea about the proximity wake feature though? That's an important feature to me... for some strange reason :p
  7. theshinybeast Lollipop Jun 28, 2017
    It's there.
    luigimario likes this.
  8. exxd Cupcake Aug 1, 2017
    exxd, Aug 1, 2017 :
    Paranoid vs vertex? Any thoughts guys? I'm currently on RR
  9. KforHorizon Jelly Bean Aug 2, 2017
    KforHorizon, Aug 2, 2017 :
    Vertex will be smoother, PA will have better battery life with being smooth enough (not as smooth as Vertex).
    Vertex is more stable than PA and has less bugs.
    Vertex has lesser features and is stock android like, PA also has less features but it's more than what vertex has.
    Pick your poison.
    I'd go with Vertex after trying PA.
    Dhiren Velari and Millig like this.
  10. luigimario The Lab - OnePlus 6T Reviewer Mar 1, 2019
    luigimario, Mar 1, 2019 :
    Hey there Beastmaster , sorry to bump an old thread but it seemed like the right place to ask. Wondering if you have any experience with Skydragon for the OP3?
    Two things I was trying to figure out but couldn't find: how often do they put out updates (monthly security at least?), and does it support dash charge?
    Hope you're doing all right :)
  11. BeingIncog Marshmallow Mar 1, 2019
  12. BeingIncog Marshmallow Mar 1, 2019
    BeingIncog, Mar 1, 2019 :
    Join telegram group and updates channel!
    Yep!!!
    Yes, thanks, tired!!! Was not meant for me but...
  13. BeingIncog Marshmallow Mar 1, 2019
  14. luigimario The Lab - OnePlus 6T Reviewer Mar 1, 2019
    Haha, no worries. Appreciate the reply. Not sure what telegram is though, similar to discord? So in your experience, are they pretty regular with updates?
    Oh no! How so? Is it no good for a daily driver? Is there a more stable ROM you'd recommend?
    BeingIncog likes this.
  15. theshinybeast Lollipop Mar 1, 2019
    theshinybeast, Mar 1, 2019 :
    Sup. Never tried Skydragon.
    Right now I'm jumping between AOSiP and LOS 16 which I reckon are the cleanest ROMs right now. Both are updated regularly and are daily driver ROMs.
    Of course, best is relative as we're all different and have different preferences.
  16. theshinybeast Lollipop Mar 1, 2019
    Oh, and don't be sorry about bumping the thread, that's what it is for, questions, opinions, suggestions etc. ;)
  17. BeingIncog Marshmallow Mar 1, 2019
    None of the pie ROMs are, coz OnePlus hasn't update their device! I'm lazy and now I have no time to flash and USB 2.0 type c is pain in the a s s!
    It's like whatsapp!!!
  18. theshinybeast Lollipop Mar 1, 2019
    Try Dian's LOS16.0 with Caesium kernel, working fine for me.
  19. luigimario The Lab - OnePlus 6T Reviewer Mar 1, 2019
    Coolio, thanks guys. I'll keep that in mind, and hopefully the ROMs get better after the official OP3 pie drops.
  20. luigimario The Lab - OnePlus 6T Reviewer Mar 1, 2019
