102
[OP3T Q&A] Noob Friendly Q&A Help Thread - Ask Your Questions Here!!
  1. ghostofcain Lollipop Oct 8, 2018
    ghostofcain, Oct 8, 2018 :
    If you reverted to 5.0.4, with wipe? And the problem persists then it's a hardware issue.
  2. thiyaga0906 Froyo Oct 9, 2018
    thiyaga0906, Oct 9, 2018 :
    Thanks for your reply...
    I didn't do anything, It's working again...
  3. Bredlin Cupcake Oct 9, 2018
    Bredlin, Oct 9, 2018 :
    Hey
    After placing do not disturb in my OnePlus 3t the notification sound will hear
    How will I fix this issue
  4. Bruxner Gingerbread Oct 9, 2018
    Bruxner, Oct 9, 2018 :
    This is because it needs to wait to see if you are double pressing it and activating a quick action. The device needs to do this. sorry for any inconvenience.
  5. Bruxner Gingerbread Oct 9, 2018
    when you put it in do not disturb Tao the settings button and configure it so no calls or messages can come through.
  6. Bredlin Cupcake Oct 9, 2018
    already I tap it as no call or message
  7. liuk5 Cupcake Oct 29, 2018
    liuk5, Oct 29, 2018 :
    Hello everyone,
    I would like to download the OxygenOS 5.0.6 version from the oneplus website. However, it seems that only the 5.0.4 is available for download.
    Can somebody please tell me why, and possibly where to download the latest OS version? Thanks
  8. BeingIncog Marshmallow Oct 29, 2018
    BeingIncog, Oct 29, 2018 :
    downloads.oneplus.com
  9. G_Sathwik_PS_egGK Cupcake Oct 29, 2018
  10. F_Akarsh_Acharya_SlAE Donut Oct 29, 2018
    F_Akarsh_Acharya_SlAE, Oct 29, 2018 :
    Hello my one plus 3 camera is not focusing after updating oxygen os 5.0.6 can i get to know is is a software bug or physical damage...can i get it fix in onplus service center for free...?
  11. G_Mohit_Kakad_xYcD Eclair Nov 1, 2018
  12. Arjun Ajay Cupcake Nov 1, 2018
  13. injo1971 Froyo Nov 1, 2018
    injo1971, Nov 1, 2018 :
    I got 2 simple questions, I did a search but keywords pop up too many other results.
    I own a 3T, currently running ressurection remix 6.2, its based off Android 8.1.
    Currently, oneplus roms for 3T are 8.0 only.
    1. Will oneplus ever move to 8.1 or 9 for the 3T?
    2. is it possible for custom rom to bake Pie-based roms for the 3T?
    Thanks!
  14. Arvind_verma Cupcake Nov 2, 2018
    Arvind_verma, Nov 2, 2018 :
    Do anybody know what is oneplus dashboad ?, It is consuming much memory and battery after android OS and System.It's battery usage is also integrated in Android System, I don't even use dashboard widget.
  15. H1541150642533 Cupcake Nov 2, 2018
    H1541150642533, Nov 2, 2018 :
    There is problem in camera after updating Android 8.00 to OnePlus 3 mobile. could you please resolve the issue.
  16. Arvind_verma Cupcake Nov 2, 2018
    This is a common issue with most 3T devices, you can get free camera module replacement at service center.
  17. BeingIncog Marshmallow Nov 2, 2018
    BeingIncog, Nov 2, 2018 :
    Nope!!!
    Yep!!!
    Clear cache!!!
    Clear cache!!!
    Directly 9.0.0 and will skip 8.1.0!!!
    Try pie on your 3T yourself, they are available now, check xda!!!
  18. sammerasker Ice Cream Sandwich Nov 2, 2018
    sammerasker, Nov 2, 2018 :
    overheating while playing a resource intensive games (Like Pubg) is normal, this an old chip sd820/821, and it was known for some overheating to begin with... the device (kernel) tries to control the heat and that what causes lags.
    How to fix it? this is not OnePlus problem, your hardware wasn't made to play such games , that doesn't mean you can't or it's incapable of it.
    you just need to be sensible.
    1- expect a little heat (not much)
    2- play at lower settings.
    3- try one of the GFX+ tools for pubg i use the paid version of the following
    https://play.google.com/store/apps/details?id=inc.trilokia.pubgfxtool.free
    but the free version works as well...
    search for settings for OnePlus 3 and apply them and your game will be smooth with little heat.
    again, OnePlus 3/3T have SD820/821 , they're not built with cooling solution to help with such games, so Heating is normal...OnePlus has noting to do with it.
    edit/ this article also may help
    https://www.xda-developers.com/improve-fps-pubg-android-games-gfxtool/
  19. Mohd Abubakar Eclair Nov 4, 2018
    Mohd Abubakar, Nov 4, 2018 :
    is oneplus still replacing the faulty camera modules for free on oneplus 3t cause my unit has that issue
  20. Arvind_verma Cupcake Nov 4, 2018
    Arvind_verma, Nov 4, 2018 :
    Yes
