106
[OP3T Q&A] Noob Friendly Q&A Help Thread - Ask Your Questions Here!!
  1. Paschfire KitKat Jul 17, 2019
    Paschfire, Jul 17, 2019 :
    What version(s) of Magisk?
    v19.3> is the latest stable version.
  2. legaceemwangz Cupcake Jul 17, 2019
    legaceemwangz, Jul 17, 2019 :
    Yeap.. Tried it to no avail.. Tried unSU then flash magisk again, no luck.. BTW js discovered another issue, phone doesn't vibrate after oos 9.0.4 update, wot cud it be..
  3. N1563442211648 Cupcake Jul 18, 2019
    N1563442211648, Jul 18, 2019 :
    Hi all, i am using OP3 and i had a problem recently regarding lock/unlock button. I am unable to either lock/unlock using that button. It happend to me after removing my mobile from charge. Can you guys help me how to get rid of this problem?
  4. Paschfire KitKat Jul 18, 2019
    Paschfire, Jul 18, 2019 :
    I suggest you backup any important data and reflash OOS 9.0.4, followed by performing a factory reset.
    Then proceed with installing Magisk.
  5. imsushantjain Froyo Jul 22, 2019
    imsushantjain, Jul 22, 2019 :
    How can i enable Google Wellbeing on OnePlus 3T using Oxygen OS 9.0.4?
  6. D1559854726593 Cupcake Jul 22, 2019
    D1559854726593, Jul 22, 2019 :
    Three questions:
    - I'm on 9.0.4, rooted with Magisk and often (~3x a day) experience freezes and need to force reboot my phone. Do you also experience that?
    - Is split screen gone on Pie?
    - When I upgraded from 9.0.3 to 9.0.4 I was forced to format my phone annoyingly. Had a TiBu backup, but not internal storage. How can I avoid that this happens with the next update?
  7. madmanmeakin Cupcake Jul 23, 2019
    madmanmeakin, Jul 23, 2019 :
    Hello, I have a OnePlus 3 with TWRP, it came with it and I've only started looking into how to use it today... The phone wouldn't update beyond it's 2017 version, So I've just folowed the steps and succesfully flashed the latest full OTA zip.
    I then rebooted system as per the steps, and now the phone screen is off with its notification LED in top left on white.. its been like that for the last 15mins... HELP
    EDIT: The updated OS is on now, but it wiped everything.. including TWRP? Should I try reinstall TWRP? Or just crack on and start fresh? :'( I did copy most the entire storage of the phone onto my computer beforehand, but I dont think that can reinstate aps and things...
  8. Paschfire KitKat Jul 23, 2019
    Paschfire, Jul 23, 2019 :
    That question can only be answered by you. Do you need/want TWRP?
  9. legaceemwangz Cupcake Jul 27, 2019
    legaceemwangz, Jul 27, 2019 :
    hello folks, js givin u sum feedbk, so i installed a custom rom (rooted) js have one problem, vibration is dysfunctional, sometimes it works sometimes doesnt.. same problem when i used oos.. any solutions?
  10. Paschfire KitKat Jul 27, 2019
    Paschfire, Jul 27, 2019 :
    Call a OnePlus service center, likely a HW issue.
  11. legaceemwangz Cupcake Jul 29, 2019
    legaceemwangz, Jul 29, 2019 :
    quick qstn: wch is better performance and battey life mod between crossbreeder lite and fde.ai?
  12. Paschfire KitKat Jul 29, 2019
  13. legaceemwangz Cupcake Jul 29, 2019
    they are magisk modules that are supposedly supposed to increase phone battery life and enhance performance at d same tym..
  14. Paschfire KitKat Jul 29, 2019
    Paschfire, Jul 29, 2019 :
    Try them both, find out for yourself if they make any Improvements with your particular usage.
    ghostofcain and legaceemwangz like this.
  15. Paschfire KitKat Jul 29, 2019
    Though I wouldn't hold my breath in expecting much. As most of these types of tweak mods don't do very much.
  16. legaceemwangz Cupcake Jul 29, 2019
    Paschfire likes this.
  17. legaceemwangz Cupcake Jul 30, 2019
    legaceemwangz, Jul 30, 2019 :
    is rher any mod that let's the fingerprint sensor act like of a moto e4 (slide left for back, right for recents
  18. drsoumyaranjan Donut Jul 30, 2019
    drsoumyaranjan, Jul 30, 2019 :
    My one plus 3 is switching off automatically after sometimes when not using, was charged to 100, does this happens when it is without sim? Wat to do and how to check problem with possible fix
  19. Fhdshahzad Gingerbread Jul 30, 2019
    Fhdshahzad, Jul 30, 2019 :
    Go to Recovery mode and delete cache then Reboot the phone.
    Check if this helps.
  20. ghostofcain Marshmallow Jul 31, 2019
    ghostofcain, Jul 31, 2019 :
    No, that would require hardware support.
