124
[OP3T Q&A] Noob Friendly Q&A Help Thread - Ask Your Questions Here!!
  1. _marxwan
    Donut Feb 17, 2020
  2. legaceemwangz
    Cupcake Feb 25, 2020
    legaceemwangz , Feb 25, 2020 :
    guys my camera app tripping.. taking photos quite alright but then the inage js goes green after a few seconds
  3. M1581532016974
    Cupcake Feb 26, 2020
  4. I1583499550353
    Cupcake Mar 6, 2020
    I1583499550353 , Mar 6, 2020 :
    my fingerprint sensor is not working not even its and functioning anymore rest keys are working and not even on settings there is nothing reflecting for fingerprints sensor
  5. V1583513993814
    Cupcake Mar 6, 2020
  6. Z1521998750865
    Cupcake Mar 8, 2020
    Z1521998750865 , Mar 8, 2020 :
    Google play store is not opening in my phone
    can't install/update any of the apps
    tried many ways to fix this but doesn't work
    how should i fix this can anyone suggest?
  7. M1570375614144
    Donut Mar 8, 2020
    M1570375614144 , via OnePlus 5T , Mar 8, 2020 :
    Will OnePlus 3T get Android Security updates...since they no longer will support new android 10....
    if they update security..how many years of it..and how about android 9 bug updates
  8. salman8896
    Cupcake Mar 9, 2020
    salman8896 , via OnePlus 3 Graphite , Mar 9, 2020 :
    My alert slider stuck in mute mode and it does't go back to normal mode but when i restart my phone its in normal mode but when i use slider again it goes back to mute mode and stucked. Please help me to get out from this issue please help.
  9. PTuT
    Jelly Bean Mar 9, 2020
    PTuT , via OnePlus 3 , Mar 9, 2020 :
    As far as I understand, active support for OP3/3T ended. If you want fixes/security updates you need to look at custom ROMs.
  10. PTuT
    I would suggest to safe boot the device and see if the alert slider is still misbehaving.
  11. chinya11
    Donut Mar 13, 2020
    chinya11 , Mar 13, 2020 :
    Hi Friends,
    In my OP3, I am not able to see the option to enable VOLTE in SIM and Nerwork settings. Can anyone please help me in this? How can I get it back?
    Thanks,
    Chinmay.
  12. andQlimax
    Honeycomb Mar 15, 2020
    andQlimax , Mar 15, 2020 :
    Probably depends on your operator, try to check that
  13. chinya11
    Donut Mar 15, 2020
    chinya11 , Mar 15, 2020 :
    Thank you for the reply. I already checked with operator (Airtel India)and they said VOLTE is enabled from their end. I think irrespective of operator, option for turning volte on/off should be present. I also tried *#*#4636#*#* and found that it is not provisioned and the button for provisioning it is disabled.
  14. G_narayana_rao_kandregul
    Cupcake Mar 16, 2020
    G_narayana_rao_kandregul , Mar 16, 2020 :
    my one plus 3t device getting turned off randomly from couple days. Even I am trying to restart by long pressing the power button, some times taking too much of time to turn on the phone or some times not turn on.. Guys, plz suggest me the solution to fix this issue?
  15. D1520518866111
    Cupcake Mar 18, 2020
  16. _marxwan
    Donut Mar 23, 2020
    _marxwan , Mar 23, 2020 :
    sorry to hear about that
    must be an hardware problem.
    go to the settings menu - buttons and gestures - buttons
    and turn on on-screen navigation bar
    ghostofcain likes this.
  17. I1586904210768
    Cupcake Apr 14, 2020
  18. I1586904210768
    I1586904210768 , via OnePlus 3T , Apr 14, 2020 :
    having the same issue
  19. F_Ch_Harish_etTr
    Cupcake Apr 15, 2020
    zafir786 likes this.
