124
[OP3T Q&A] Noob Friendly Q&A Help Thread - Ask Your Questions Here!!
  1. Paschfire , via OnePlus Community App , Jan 25, 2021 :
    I'm sorry to say, but you're expecting a lot from very outdated HW/SW. Even with root and available tweaking, you'll likely only yield small performance gains.
    The unfortunately truth is...
    If you want to run, play, highly graphically intensive games.
    Using, purchasing, a newer device with newer HW/SW capable of such tasks is the only real solution.
  2. Paschfire , via OnePlus Community App , Jan 25, 2021 :
    I Loved my 3T. Yes Rooted, TWRP recovery, custom ROM and custom Kernel, as well all the tweaking you could think of.
    Though after I purchased a Pixel 4 XL about 10 Months ago, it was night and day the performance differences between the two devices.
    Keeping up with todays ever changing, highly demanding Mobile gaming space, you need a device that can handle the demanding load these game put on current GPU/CPU technology.
    Another year and I'll even me looking for something newer to keep up too. My personal experience any see device older than 2 yrs old(<SD845) is in the running for a HW upgrade.
  3. OzzyJay
    Ice Cream Sandwich Jan 31, 2021
  4. PriteshBM
    Cupcake Feb 1, 2021
  5. H1560670749348
    Cupcake Feb 27, 2021
    H1560670749348 , Feb 27, 2021 :
    Hi All,
    My home button is not working from few days and finger print option is also missing from the settings tab. can anyone help me with this?
  6. McJader
    Marshmallow Feb 27, 2021
    McJader , Feb 27, 2021 :
    Are you using the 3T?
  7. H1560670749348
  8. McJader
    Did the phone drop into any liquid or came into contact with a liquid, by any chance?
  9. H1560670749348
    Nothing like that happened... everything was working fine till yesterday. I just cleared some app storage, restarted my phone. From then I am facing this problem
  10. Bobbie63
    Bobbie63 , Feb 27, 2021 :
    Type into the dialer *#808#, you'll get into factory mode, swipe left to device debugging (top of screen) select finger print test finger print auto test and perform them both and check the outcome
    McJader likes this.
  11. H1560670749348
    I tried that as well but it's saying " Application can't reach the android service for the server"
  12. Bobbie63
    I'm sorry to hear that, can’t even tell what it means tbh. It almost looks like it's trying to connect to some server but as far as I know it's a stand alone test.
    If you try to test anything else, does it give you the same error?
  13. H1560670749348
    I tried for some other options like keypad testing, touch etc and they are not throwing any errors
    looks like this is specific to finger print
  14. Bobbie63
    So maybe that might implicate the home button stopped functioning. I don't know if there is some other fingerprint or home button test though.
    I could tell you to perform a factory reset (after backing up all important data) but I don't think it's a solution
    McJader likes this.
  15. Bobbie63
    McJader likes this.
  16. O1615720709426
    Cupcake Mar 14, 2021
    O1615720709426 , Mar 14, 2021 :
    I have issue with my OnePlus 3t. it's camera gone blur when mobile take staright. it's gone be clear when mobile take down I can't take clear pic of straight sight pic why ?
  17. Y1592804900408
    Cupcake Mar 18, 2021
    Y1592804900408 , Mar 18, 2021 :
    I have One Plus 3Tand my screen has pink shade in corner. The pink screen is just 10% right now but it's expanding. Please help me.
  18. ericOWNS
    Cupcake Apr 7, 2021
  19. SomeFlashlight
    Cupcake Apr 8, 2021
    SomeFlashlight , Apr 8, 2021 :
    The keyboard or notifications, or both, stopped working properly. The keyboard has ceased to hide when it is not needed and to appear in the foreground when needed. I open notifications and press quick reply, the keyboard remains in the background and at the same time is active, a touch in the keyboard area is accepted, but I cannot remove it with a gesture and the buttons in notifications do not work. Explicit issue of priorities and image overlap
