123
[OP3T Q&A] Noob Friendly Q&A Help Thread - Ask Your Questions Here!!
  1. lbeier
    Donut Mar 15, 2017
    lbeier , Mar 15, 2017 :
    I've unlocked the bootloader and installed TWRP and SuperSU on my OnePlus 3T and now I have two questions:
    1) I'm wondering how can I apply a new update? I need to to download the zip file and apply it manually via TWRP? What will happen if I apply them via "Systems Updates" menu?
    2) What about partial updates? Can I apply them via "System Updates" menu?
  2. F_Rajgiri_B_Reddy_LYKD
    Cupcake Mar 15, 2017
  3. F_Rajgiri_B_Reddy_LYKD
  4. G_sathiya_J_QzXe
  5. Hxc
    Froyo Mar 15, 2017
    Hxc , Mar 15, 2017 :
    it is 3 months now and the battery drain problem didnt decreased and when the battery reaches to 45 to 35 percent it automatically heates up in my pocket i have done 2 reset or cleared whole data still the problem didnt went
    please suggest me any solution or bring an update
  6. Hanoch Cohen
  7. Master_TC
    Jelly Bean Mar 15, 2017
    Master_TC , Mar 15, 2017 :
    1) Yes always full zip and update over TWRP. Else you will get an error.
    2) the same like 1)
  8. will3277
    Froyo Mar 16, 2017
    will3277 , Mar 16, 2017 :
    You guys were right. I just got my A3000. Had it for about 20 min now and its already on the beta oxygen.
  9. elanglois
    Lollipop Mar 16, 2017
    elanglois , Mar 16, 2017 :
    Yeah, Beta is betta :)
  10. Niccover
    Cupcake Mar 16, 2017
    Niccover , Mar 16, 2017 :
    Hello, first of all English is not my mother tongue so I hope there will not be misunderstandings...
    Here's my problem, I used to have my news section (swiping leftwards my homepage and selecting the forecasts). Now, I don't know what I did but there are no more news for me except for the weather forecasts, even if I am sure I have selected the option that should allow my phone to continuously improve my feed with web sides and so on...
    So... How can I display again my news?
  11. AkashGupta69
  12. jmv1
    jmv1 , Mar 16, 2017 :
    Updating to newest firmware seems to have resolved the problem. Greatness! :cool:
  13. will3277
    Froyo Mar 17, 2017
    will3277 , Mar 17, 2017 :
    hey. such a nub issue here.
    I can't root.. bl is unlocked, TWRP installed, running new 7.1.1.
    all apps say I don't have root. I try to flash su from unlock thread but it just boot loops when I try, then I have to restore nand backup.
    plz help if u can.
  14. yuezhouh
    Eclair Mar 17, 2017
    yuezhouh , Mar 17, 2017 :
    Flash stable systemless SuperSU 2.79 from here: https://forum.xda-developers.com/apps/supersu/stable-2016-09-01supersu-v2-78-release-t3452703
    Alternatively, you can flash Magisk v11.1, which works just as well
    will3277 likes this.
  15. yuezhouh
    Eclair Mar 17, 2017
    Has OOS 4.1.0 removed the "disable IpV6" option in the Wifi menu? My Wifi performance is terrible without it...
  16. VaibhavRamani
    Eclair Mar 17, 2017
  17. Raveen Vishnu
    Cupcake Mar 17, 2017
  18. Major1153
    Eclair Mar 17, 2017
    Major1153 , Mar 17, 2017 :
    how does the duel sim work on the 3t?
    as i want to use sim 1 for calling and text and then sim 2 for data, but im not sure if i could use both sims at the same time
  19. wenna
    Ice Cream Sandwich Mar 17, 2017
    wenna , Mar 17, 2017 :
    I believe adb has port forwarding command.
    adb forward tcp:32400
  20. nexusone2
    Donut Mar 17, 2017
    nexusone2 , Mar 17, 2017 :
    display gets blank when incoming calls are to connect. cant disconnect from my side. is this update issue or need to update first.
