OP3T unlock issue
  1. osama_e Cupcake Jul 12, 2019
    osama_e, Jul 12, 2019 :
    Hi guys,
    I am having a strange issue with my OP3T (the issue was in Oxygen OS 9.0.3 and still exit in the latest update 9.0.4) as I tried to swipe down to get the status bar from the lock screen then swipe up again to return back to the lock screen.
    The phone gets unlocked without any input to the finger print sensor and with the front camera covered!
    Does anyone have the same issue?
    Update: I tried with face unlock disabled with no success.
  2. Intruder71 Lollipop Jul 12, 2019
    Intruder71, Jul 12, 2019 :
    If only there was a way to search.... Turn smart lock off
  3. osama_e Cupcake Jul 12, 2019
    I tried with face unlock disabled and I am still facing the same problem.
  4. Intruder71 Lollipop Jul 12, 2019
    Location? Just turn it all off as I said... Or you could read and learn how to use it properly.
  5. Madnezz4Ever Ice Cream Sandwich Jul 12, 2019
    Madnezz4Ever, Jul 12, 2019 :
    You need to disable Smart Unlock and remove everything under the settings for it such as Trusted Devices, Trusted Places and so on.
  6. osama_e Cupcake Jul 12, 2019
    Thank you guys for the help.
    I found the issue and it was in Smart lock settings as suggested, On-body detction was enabled! [e]1f601[/e]
