[OP5/5T] Copy Issue
  1. Raja1609 Cupcake Jul 21, 2019
    Raja1609, Jul 21, 2019 :
    Hi Team,
    I am facing issue while copying large files from PC to OnePlus 5T. It's not getting copied. please help me to fix the issue
  2. Cervantes Lollipop Moderator Jul 21, 2019
    Cervantes, Jul 21, 2019 :
    Hi
    What steps do you follow to connect the phone to the computer
  3. Raja1609 Cupcake Jul 21, 2019
    Hi,
    I am using USB cable to transfer file between computer to device
  4. Cervantes Lollipop Moderator Jul 21, 2019
    You installed the driver
    active usb debugging
    change charge to file transfer
  5. Raja1609 Cupcake Jul 21, 2019
    Yes, I did all.. but still having issue
  6. Cervantes Lollipop Moderator Jul 21, 2019
    You restart the computer after installing the driver
    what type of file and how large the files are
  7. Raja1609 Cupcake Jul 21, 2019
    ok. I am copying cloud tutorial course which consists MP4, html, txt files and the size is 10GB
  8. Cervantes Lollipop Moderator Jul 21, 2019
    a file of 10 gb is very large, it is advisable to copy by parts
  9. Raja1609 Cupcake Jul 21, 2019
    I have tried that as well but no luck
  10. Cervantes Lollipop Moderator Jul 21, 2019
    What operating system do you have and what version of the system
  11. Raja1609 Cupcake Jul 21, 2019
    I am having windows 10 home edition
  12. blacklistedjio Froyo Jul 21, 2019
    blacklistedjio, Jul 21, 2019 :
    I'm. also having the same issue with oneplus5.. tried to copy 29gb files to pc and getting error that device is not functioning.. tried installing usb drivers and still having the same issue... any idea..?
    I also tried to transfer files from SHAREit mobile to SHAREit pc and getting cancelled automatically..
    any solution to transfer large files?
  13. B1514900966419 Gingerbread Jul 21, 2019
  14. Raja1609 Cupcake Jul 21, 2019
    ok Sure.. will try and let you know if issue persist..
    Thanks.
  15. Raja1609 Cupcake Jul 23, 2019
    Raja1609, Jul 23, 2019 :
    Hi,
    I have tried by disabling optimisation as well but no luck..
