2
OP5 charging on and off issue
  1. prateek_95
    Cupcake Aug 26, 2018
    prateek_95 , Aug 26, 2018 :
    I have been facing a weird issue when I charge my OP5. The charging keeps on going on and off automatically. At first I thought its a problem with my charging cable but when I use the same cable to charge my mom's MI A1, it works perfectly.
    I found a couple of threads on the forum where people were facing similar issues with their OP5T, but I didn't find any solution.
    What do you think guys ? Anyone else facing similar problem?
  2. lakshaykapoor99
    Honeycomb Aug 26, 2018
    lakshaykapoor99 , Aug 26, 2018 :
    I have been facing the same problem. Although it happens occasionally, sometimes it works, sometimes it doesn't! I think it is a problem in the cable only, cause I can't seem to find any other logical conclusion!
    L1516377248152 likes this.
  3. Yann Ditengou
    Froyo Aug 26, 2018
    Yann Ditengou , Aug 26, 2018 :
    Happens to me too from time to time but when it happens I have to jiggle the cable till it works... When I plug it in my friends s8 it works perfectly.
  4. G_Wen_Ou_cajr
    Eclair Aug 26, 2018
  5. Prajwal_
    Froyo Aug 26, 2018
  6. Prajwal_
    Froyo Aug 26, 2018
  7. prateek_95
    Cupcake Sep 2, 2018
    prateek_95 , Sep 2, 2018 :
    hi guys, i guess I found the solution for this. It's basically the dust particles inside the charging port which is creating this issue. Spend 10 minutes in cleaning your charging port in the phone and i hope yhe problem will be solved. These dust particles or parts of cotton come when we keep our phones in my pocket.
    I hope this will solve the issue.
    Rocdsand likes this.
  8. Rocdsand
    Gingerbread Sep 2, 2018
    Rocdsand , Sep 2, 2018 :
    For you are dust, and to dust you shall return.
