5
[Answered] OP5/OOS 9.0.1 Pie: Few apps not working under wifi, works fine with mobile data
  1. vbhoj74
    Donut Dec 27, 2018
    vbhoj74 , Dec 27, 2018 :
    After update to Android pie, few apps like Twitter, Youtube, Netflix etc are not working with wifi connection, Amazon prime video works. When using mobile data everything starts to work. I did a factory reset and installed everything all over again, tried 2.4ghz only WiFi, different router, still the same thing.
    Edit: Makeshift way if you have to use wifi till this bug is patched, use VPN, except Netflix, everything else will work.
    Edit: updated to OOS 9.0.1 (build 181229) , issue still exists, and the phone is pretty useless without WiFi functioning properly.
    shivam_adi, pibo99, sahgal and 2 others like this.
  2. vbhoj74
    Donut Dec 27, 2018
    Hi, did not initially understand "Probablility of occurance", the issue is present 100% of the time.
    shivam_adi likes this.
  3. raghavrastogi07
    Donut Dec 28, 2018
    raghavrastogi07 , Dec 28, 2018 :
    Similar problem, I tried resetting my phone and network, even changed my router. Tried to connect to another WiFi but the efforts were futile.
    The following apps only work on the mobile network and not on the WiFi network.
    1. Netflix
    2. LinkedIn
    3. Amazon Music
    4. Twitter
    5. Yahoo Mail
    I'm using JIO as my primary SIM for Data and Vodafone for Voice and Airtel Broadband for WiFi.
    A minor workaround for Netflix that I found was, Start streaming your content on mobile data and in between switch to your WiFi Network. Works for me, but a proper solution will be appreciated.
    Let's merge all the threads with a similar problem to one Mega-thread to quickly find a solution or escalate the issue so it is noticed.
  4. vbhoj74
    Donut Dec 29, 2018
    vbhoj74 , Dec 29, 2018 :
    Same, even I tried with another Wifi Network, switched to 2.4Ghz SSID only, still no go.
  5. dpka.shek
    Froyo Dec 29, 2018
  6. nikhilendrapratap
    Gingerbread Dec 29, 2018
  7. shg1012
    Cupcake Dec 29, 2018
    shg1012 , Dec 29, 2018 :
    Same thing happened to me too. Not working on wifi but working on mobile network. If you switch bitween wifi while streaming it works. But then you go back and start again, it won't.
  8. vbhoj74
    Donut Dec 30, 2018
    vbhoj74 , Dec 30, 2018 :
    another input: all the apps except netflix works with VPN over WiFi connection. Netflix still does not work because it blocks VPN networks.
  9. Sid_Ck
    Ice Cream Sandwich Dec 30, 2018
    Sid_Ck , Dec 30, 2018 :
    Can you please report this as a bug as when I'm doing it logs out in the login page
  10. vbhoj74
    Donut Dec 30, 2018
    I believe this thread itself is filed as a big report. Can u give me a link if there is another way to file bug report?
    meanwhile, I guess it prioritises if more policy like and follow this bug report.
  11. grk007
    Honeycomb Dec 30, 2018
    grk007 , Dec 30, 2018 :
    Same for me Instagram, chrome and Facebook app is not working in WiFi ..but it works fine in mobile data.. connected to 5ghz WiFi..
  12. vikram.vallala
    Cupcake Jan 2, 2019
    vikram.vallala , Jan 2, 2019 :
    Facing the same issue. OnePlus Team please respond, there is no fun with the Android Pie due to this issue.
    Apps not working on WiFi not only the mentioned apps, the issue includes the Bank Apps, Tik-Tok which is very annoying. Help us here, all the apps works on Mobile Data which costs us more.
    My Phone is OnePlus 5T, this issue was after installing the Android Pie. 9.0
  13. pedroski691
    Cupcake Jan 2, 2019
    pedroski691 , Jan 2, 2019 :
    don't worry y have OP6 and when I instal android pie 9.0 first time it make problems but after a few days other update come to solve the problems now i dont have any problem.
  14. Srinivas.T
    Cupcake Jan 9, 2019
  15. pibo99
    Cupcake Jan 9, 2019
  16. Bobby D.
    Gingerbread OnePlus Bug Hunter Jan 10, 2019
    Bobby D. , Jan 10, 2019 :
    Hi vbhoj74,
    This is Bobby from OnePlus Bug Hunters.
    Please kindly note that the issue will be fixed in next update. Please wait and check if it works then.
    Any other bugs you find, please contact me for further help. Or you can submit bug report here: https://forums.oneplus.com/feedback/ next time so that we can see your issues intuitively for further investigation.
    High regards
    OnePlus Bug Hunters
  17. vbhoj74
    Donut Jan 10, 2019
  18. pibo99
    Cupcake Jan 10, 2019
  19. vbhoj74
    Donut Jan 11, 2019
  20. pibo99
    Cupcake Jan 11, 2019
    pibo99 , Jan 11, 2019 :
    Updated to 9.0.2 twitter for now is ok but app like oneplus comunity cant load and games cant be update ingame. Games like epic 7 and grandchase.
