Battery/Charging OP5T not charging "correctly"
  1. Benjamin Madsen
    Cupcake Jan 8, 2020
    Benjamin Madsen , Jan 8, 2020 :
    Hi, i have had my 5T for almost two years (purchased april 2018) and it has completely stopped dash-charging and can only charge when the charger is turned one way.
    I have tried getting rid of dust with a toothpick and compressed air, the charging port seems completely clear now, but still no change in the charging.
    I also tried with multiple chargers and nothing works, it's as if the charger does not go all the way in even though the port is clean.
    EDIT: Have also tried a brand new OP7T charger now, still the same.
    I'm completely lost, what could be the problem?
  2. Horsault
    Marshmallow Moderator Jan 8, 2020
    Horsault , Jan 8, 2020 :
    Dash charge has always and will only work when using original charger AND cable, on a stable and good quality power grid, if all the ports and sockets are perfectly clean of all dust and objects and USB port isn't loose.
  3. Benjamin Madsen
    Cupcake Jan 9, 2020
    Benjamin Madsen , Jan 9, 2020 :
    I mean i tried it with one other oneplus 5T charger :)
  4. Davidwane
    Cupcake Jan 20, 2020
    Davidwane , Jan 20, 2020 :
    the same issue happend to me aswell. I have a 5t at the same age as yours. Its only charges when I Close down the device. I have tried with a Another dash charger (oneplus) with out any results.
