OP5T overheating
  1. LMeneses31
    Cupcake Apr 4, 2018
    LMeneses31 , Apr 4, 2018 :
    hi everyone,
    today my 5T started overheating only with 4G data turned on.
    i had to turn it off and restart phone to let it cool down.
    has anyone experienced the same issue?
    Br,
    Meneses31
  2. stark2991_PL
    KitKat Apr 4, 2018
    stark2991_PL , Apr 4, 2018 :
    What does mean "overheating"? Was it slowing down?
    Is it summer now where you live?
  3. LMeneses31
    Cupcake Apr 4, 2018
    hi, no here is Spring.
    The phone somewhat started to warmup for no reason. I went to see the hours and the phone was soo hot like if i was gaming for hours. Maybe it was an app that was causing this issue, I can't tell for sure.
    I restarted the phone and the temperature went normal again.
    Br,
    LMeneses31
  4. stark2991_PL
    KitKat Apr 4, 2018
    It was probably one of your apps running in the background. Next time check battery usage before restarting
    Abhi Dahiya likes this.
  5. LMeneses31
    Cupcake Apr 4, 2018
    thanks, i will try that.
    Br,
    LMeneses31
  6. Speedlover777
    Honeycomb Jul 9, 2018
    Speedlover777 , Jul 9, 2018 :
    Same issue on my 5T (Android 8.1.0., Oxygen OS 5.1.3.). Today, the device started to abnormally overheat up to approximately till 50-55° degree celcius. The device was really hot. I was just browsing Chrome, not playing games or running heavy apps. I know how devices overheat while playing heavy games, but this time the device was much more hot at the back top near rear camera, with siginificant worsening of performance.
    Probably, OnePlus developers were gathering some user experience reports in background, since I usually put all tickmarks ON for helping OnePlus developers. Pls find attached screenshot.
    The device works normally after restarting.
  7. krishnasamanth
    Cupcake Jul 9, 2018
