OP6 android 10 issues Gpay and keyboard via OnePlus 6
  1. steven_191
    Donut Nov 10, 2019
    steven_191 , via OnePlus 6 , Nov 10, 2019 :
    2 issues I've noted since the update.
    Gpay gives an error, that the device is not up to security standards,
    And I'm using SwiftKey and there's now a small blank gap along the bottom of the screen.
    I was previously rooted on a droid 9 but now have a clean android 10 install. If that's important??
    I'm keeping an eye out for any similar issues but thought it would be worth posting
    Thanks
  2. cereal_kllr , via OnePlus 6 Midnight Black , Nov 10, 2019 :
    Resetting the Google play services by going into settings>search for apps>click on apps and apps data>search for Google play services and delete data. Then do the same for Google pay app and Google play store. This method worked for. Keep in mind that if you reset all of the above, then you'll have to enter your card details again in the Google pay app.
    The small black bar is not only for Swiftkey but even for GBoard. It's a known issue.
    OscarPapa6 and steven_191 like this.
  3. steven_191
    Donut Nov 10, 2019
    cereal_kllr likes this.
  4. steven_191
    Donut Nov 18, 2019
    steven_191 , via OnePlus 6 , Nov 18, 2019 :
    I tried deleting all of the app data and cache mentioned. The Gpay app still had all my details though and it still said it couldn't enable contact less because the phone is rooted.
    It isn't rooted anymore but the bootloader is unlocked. I was going to install magisk again anyway so if it works with magisk it's a win, if not it isn't any worse.
  5. Kytharsis
    Marshmallow Nov 18, 2019
    Kytharsis , Nov 18, 2019 :
    This is an issue with the current A10 build. Wait for 10.0.1.
  6. steven_191
    Donut Nov 18, 2019
    Is there an official thread to keep track of bugs like this or is it a case of trawling through posts until you find something relevant?
  7. Kytharsis
    Yep. The update thread.
