OP6 Battery Saving Settings?
  1. AdamMcLeister
    Eclair Jun 22, 2018
    AdamMcLeister , Jun 22, 2018 :
    was just wondering if you guys could help me out with some settings that I could switch off or adjust for improved battery life.
    thanks in advance
  2. vsdeepak05
    Froyo Jun 22, 2018
    vsdeepak05 , Jun 22, 2018 :
    You can use the battery saver Which is provided in the Notification Drop down tray.
    Swipe down from Home screen- > Swipe again to expand the tray -> tap the edit icon on right hand bottom -> Check and drag the Battery saver icon to top 6.
    you can toggle on/off this to get the improvised battery life.
    Hope this helps.
  3. Deactivated User
    Jun 22, 2018
    buntycubal likes this.
