Network/Connectivity OP6: Data won't work unless I switch to 3G and back
  1. dmitri007
    Cupcake Feb 14, 2020
    dmitri007 , Feb 14, 2020 :
    I have a strange issue on my phone. My LTE data won't work(shows LTE!) unless I switch preferred network type to 2G/3G(where it shows H+) and back to 2G/3G/4G(shows LTE+). Then it works for sometime and after it gets connected to Wifi for a while, I will have to repeat this. I already had my sim replaced. Provider is mintmobile(T-Mobile MVNO). I have recently upgraded to 10.3.1
  2. DrJMun
    KitKat Feb 14, 2020
    DrJMun , Feb 14, 2020 :
    Two things: Did you upgrade from 9.X to 10.3.1 and did you reformat after you upgraded? Have you tried resetting network connections (mobile)?
    Kytharsis likes this.
  3. dmitri007
    Yes, I upgraded from 9.x to 10.3.0 and then to 10.3.1. I had issues with 10.3.0 itself. I didn't try network connections reset yet since it will delete my Bluetooth pairings.
