OP6 not dash charging via OnePlus 6
  1. Sagar_surya
    Cupcake Feb 22, 2020
    Sagar_surya , via OnePlus 6 , Feb 22, 2020 :
    My OnePlus6 all of a sudden stopped dash charging. I know it could be some hardware issue. Just wanted to check if any users facing the same. I showed it to a local service center and they are saying to replace charging unit.
    But, it's charging for me only dash charge is not happening. Let me know if any of you faced same issue and what you did for that?
    Thanks.
  2. Mr.Steve
    Gingerbread Feb 22, 2020
    Mr.Steve , via OnePlus 6 , Feb 22, 2020 :
    So you're issue is "fast charging" not working , but your mobile is charging in normal way !!
    Have you tried any other oneplus chargers with your mobile ?
    If the fast charging doesnt shows up ,even with other oneplus chargers , your usb port should be damaged !!
    Take your mobile to an official or authorised service centre , they'll refix it or replace the usb port !! ( refix cost - around 500 rs , usb port replacement cost - around 800 rs )
    Dont take it to any other normal service centre, its a very bad choice.
    DrJMun, Sagar_surya and Kytharsis like this.
  3. Sagar_surya
    Thanks for your suggestion [e]1f60a[/e]
  4. G_Alejandro_Martín_Cova
    Donut Feb 23, 2020
    G_Alejandro_Martín_Cova , Feb 23, 2020 :
    Clean the bottom of the USB Port carefully with a needle specially the round corners It worked for me
    Sagar_surya likes this.
  5. Sagar_surya
    Cupcake Feb 23, 2020
    Sagar_surya , via OnePlus 6 , Feb 23, 2020 :
    Thanks, will try it.
  6. DrJMun
    KitKat Feb 23, 2020
    DrJMun , Feb 23, 2020 :
    I'm not sure I'd use a needle as it's conductive...but to use a toothpick.
  7. G_Alejandro_Martín_Cova
    Donut Feb 23, 2020
    As I said In other post it's conductive but in vertical position cannot short any pin plus you can do It with the phone off and it'sthe best tool to scratch dirty from bottom that it's the finality i tried first with a toothpick and didnt resolve the problem.
    I have do It multiple times with phone on.
    Please report here if It worked for you.
  8. VikneshV97
    Cupcake Mar 10, 2020
