49
[Op6/t Unified thread]Speed dial contacts are auto cleared
  1. adarsh25may Cupcake May 27, 2019
  2. Q1545400353540 Cupcake May 27, 2019
  3. 18aniruddha Eclair May 27, 2019
    18aniruddha, May 27, 2019 :
    try factory reset
  4. Q1545400353540 Cupcake May 27, 2019
  5. 18aniruddha Eclair May 27, 2019
    take backup before doing it.
    it is what we do when we have to factory reset.
    once in a while factory reset is necessary to function device properly.
  6. Sudipbiswal Cupcake May 27, 2019
  7. 18aniruddha Eclair May 27, 2019
    while charging it's totally normal!
    Sudipbiswal likes this.
  8. Playa82 Donut May 27, 2019
    Playa82, May 27, 2019 :
    why should a factory reset solve this when almost everybody got the same Problem ?!?
  9. 18aniruddha Eclair May 27, 2019
    everyone has different heating issues
    1. Heating while Charging is totally Normal
    2. Extensive use of GPS
    3. Using apps that require more power or using apps for extended periods
    4. direct sunlight on device (in summer)
    5. after a software update some users experience heating issues and battery draining issues thus Factory Reset is required
  10. Playa82 Donut May 27, 2019
  11. amitator Cupcake May 27, 2019
    amitator, May 27, 2019 :
    was happening to me too. just went back on previous update. no issue now. will update when they release a fix for it.
  12. J1558967632788 Cupcake May 27, 2019
  13. G_Anuj_Poddar_DPUo Cupcake May 28, 2019
  14. 18aniruddha Eclair May 28, 2019
    18aniruddha, May 28, 2019 :
    Oneplus does not provide ETA on software updates
    tune in on Oneplus Community app you'll be the first to know
  15. KmRn7 Donut May 28, 2019
    KmRn7, May 28, 2019 :
    its changing frequently n sometimes speed dial says no contacts found
  16. imin9clouds Cupcake May 28, 2019
  17. Dleenly Cupcake May 28, 2019
    Dleenly, May 28, 2019 :
    no..
    BTW I got it again now again. Maybe because I've switched data sim.
    But before I have no this issue for a few months as I remember
  18. pravin66 Cupcake May 28, 2019
  19. X1541956353000 Cupcake May 28, 2019
  20. I1546493859267 Cupcake May 28, 2019
