58
[Op6/t Unified thread]Speed dial contacts are auto cleared
  1. ironass
    Lollipop Apr 28, 2020
    ironass , Apr 28, 2020 :
    *#*#4636#*#* is working fine on OnePlus 6T, Open Beta 6, on OnePlus phone app version 4.8.0 (250045).
  2. pavneetsurjan
    Cupcake May 2, 2020
    pavneetsurjan , via OnePlus 6 , May 2, 2020 :
    Yes I'm using stock oneplus app version 4.4.1 it is not working from the beginning I'm using a third party app for that.
  3. pavneetsurjan
    Cupcake May 2, 2020
    I was trying to install latest version it has stopped working any how i get it back running.
  4. Srk@2019
    Cupcake May 27, 2020
  5. Tee_Eee_Bee
    Ice Cream Sandwich May 27, 2020
    Tee_Eee_Bee , via OnePlus 6T , May 27, 2020 :
    Go to Settings -> Apps & Notifications, tap on See all [number] apps.
    Search for the launcher app and tap on it, then you have a couple of options:
    1. Try clearing the cache by tapping on storage & cache, then tap on clear cache.
    Try the app again and see if it now works.
    If not, try this:
    2. Tap on the 3 dots in the top right hand corner and select Uninstall updates to remove the later version you have installed.
    You can then try and re-install a newer version if you wish.
    Caoimhín and pavneetsurjan like this.
  6. pavneetsurjan
    pavneetsurjan , via OnePlus 6 , May 27, 2020 :
    I took a backup a month ago and that helped me to re install the older version . Thanks anyway [e]1f44d[/e]
  7. manasarora98
    Ice Cream Sandwich Jul 31, 2020
    maijied likes this.
  8. maijied
    Froyo Aug 6, 2020
    maijied , via OnePlus 6T , Aug 6, 2020 :
    yap. the problem is solved
  9. P1591683921847
    Cupcake Aug 16, 2020
    P1591683921847 , Aug 16, 2020 :
    My contact getting automatically lost and everytime I used do #Undo Changes in contact setting, but this time it's not even happening, I really fed up and I never ever experienced this issue in any other brand smartphones, please do help on this.
  10. Govind_s
    Donut Nov 11, 2020
    Govind_s , via OnePlus 6T , Nov 11, 2020 :
    Needs to go to settings and select app and clear cache data of call and speed dial and then restart the device.
  11. Jain Rakshit
    Donut Nov 20, 2020
  12. PreethamNarla
    Eclair Dec 2, 2020
