OP6T / Remote control for TV SONY
  1. mick1889
    Cupcake Oct 14, 2021 at 1:41 PM
    mick1889 , Oct 14, 2021 at 1:41 PM :
    Hi,
    i had a application to pilot my Smart TV SONY : Androif TV
    But these app doesn't work anymore. I deleted it, but when i want to search it i don't find it on the play store.
    No app that i download from the play store operates.
    Which app exist on OP as remote controller?
    Bonjour,
    j'avais une application que j"utilisais comme téléommande pour contrôler ma smart tv SONT: Android TV.
    L'application ne fonctionnait plus, je l'ai supprimée, et je voulais la réinstaller.
    Par contre, l'application n'est plus trouvable dans la play store.
    Aucune application disponible dans le play store ne fonctionne.
    Quelle application puis-je utiliser en tant que télécommande?
  2. dsmonteiro
    Community Consultant Staff Member Oct 14, 2021 at 2:45 PM
    Best Answer
    dsmonteiro , Oct 14, 2021 at 2:45 PM :
    Google has discontinued the Android TV Remote Control app. You can read more about it here:
    https://www.theverge.com/2021/9/27/22697167/android-tv-remote-google-tv-remote-app
    Now, the Google TV / Google Play Movies app allows you to have a built-in controller, directly from the quick settings toggle.
    Liehjan likes this.
  3. Liehjan
    The Lab Reviewer - OnePlus Buds Pro Oct 14, 2021 at 1:43 PM
    Liehjan , Oct 14, 2021 at 1:43 PM :
    There isn't a remote controller app on oneplus phones... As the phone doesn't have a IR blaster.
    drl431 likes this.
  4. mick1889
    Cupcake Oct 14, 2021 at 1:46 PM
  5. Liehjan
    The Lab Reviewer - OnePlus Buds Pro Oct 14, 2021 at 1:55 PM
    Liehjan , Oct 14, 2021 at 1:55 PM :
    There is no Android TV app installed on OnePlus phones by default. You asked which remote controller app exists on OP phones, and the answer is none... The app you describe is the google made app on Playstore that only works with AndroidTV.
    drl431 likes this.
  6. mick1889
    Cupcake Oct 14, 2021 at 2:41 PM
    mick1889 , Oct 14, 2021 at 2:41 PM :
    Yes, by default the app is not on the phone. That is OK. I ask on the play store.
    The app " Android TV" is not findbar in the play store
    The SONY SMART TV work on android.
  7. Liehjan
    The Lab Reviewer - OnePlus Buds Pro Oct 14, 2021 at 2:47 PM
    Liehjan , Oct 14, 2021 at 2:47 PM :
    It's available on APK mirror. Don't know if it works or not, but worth a try.
  8. mick1889
    Cupcake Oct 14, 2021 at 3:37 PM
  9. mick1889
    Cupcake Oct 14, 2021 at 3:38 PM
  10. dsmonteiro
    Community Consultant Staff Member Oct 14, 2021 at 3:40 PM
    dsmonteiro , Oct 14, 2021 at 3:40 PM :
    You should see it if you try to edit your quick settings toggles, as long as you have Google Play Movies installed.
  11. mick1889
    Cupcake Oct 14, 2021 at 3:45 PM
    mick1889 , Oct 14, 2021 at 3:45 PM :
    Google play movies ist installed on my phone. But i don't find the quick settings toggle.
  12. dsmonteiro
    Community Consultant Staff Member Oct 14, 2021 at 3:52 PM
    dsmonteiro , Oct 14, 2021 at 3:52 PM :
    Can you share a screenshot?
  13. mick1889
    Cupcake Oct 14, 2021 at 3:55 PM
  14. dsmonteiro
    Community Consultant Staff Member Oct 14, 2021 at 3:57 PM
  15. mick1889
    Cupcake Oct 14, 2021 at 4:00 PM
  16. mick1889
    Cupcake Oct 14, 2021 at 4:02 PM
    dsmonteiro likes this.
  17. mick1889
    Cupcake Oct 14, 2021 at 4:07 PM
