Op7 issue with calling after Android 11 upgrade via OnePlus 7
  1. V1620057240707
    Cupcake May 5, 2021
    V1620057240707 , via OnePlus 7 , May 5, 2021 :
    Having call voice issues with Android 11 upgrade on Oneplus 7.
    Read somewhere that it has a workaround for oneplus7 pro with turning on hearing aid comparability, but this option is not available for OP 7.
    Both I coming and outgoing calls go to bottom speaker directly. Switching to speaker mode does it fix the issue.
    Changing side button to Ring, vibrate, silent does not fix the issue.
  2. pablofg1978
    Head Moderator Head Moderator May 5, 2021
    pablofg1978 , May 5, 2021 :
    hello there,
    I moved your thread to a more appropiate section, Introduce yourself section is not meant for this type of content
    You can use the feedback section on the community app to submit your issues directly to OnePlus or using this link Https://forums.oneplus.com/feedback
    AprilParrish likes this.
  3. pablofg1978
    hello there,
  4. V1620057240707
    Cupcake May 5, 2021
    Thanks..somehow the app does not allow me to create in any other type of category.
  5. pablofg1978
  6. V1620057240707
    Cupcake May 5, 2021
  7. pablofg1978
    V1620057240707 likes this.
  8. V1620057240707
    Cupcake May 5, 2021
    I created one post with that as well..no response on it yet.
    Can you direct me to somewhere I can find a solution to my issue?
  9. pablofg1978
  10. Sk14kumar
    Cupcake May 5, 2021
  11. AprilParrish , via OnePlus Nord N10 5G T-Mobile , May 7, 2021 :
    Hey newbie and to all other newbies
    Okay changing the subject title @thread is not a community pass in our introduce yourself @thread. Basically it's where you let @AprilParrish and the others know you are here. In addition helps to address you proper and allows your choice of an icon picture. Therefore if an off topic is not answered here and moved someplace else where you not knowing how to get there because of lack of reading then we will do our best for you. knowing how to get the most from the community than the the run around keeps people pleased with the 1+ devices. The issue will not be our fault for discouragement, disappoinment, etc. So if a mental barrier is with you then have someone at home help you. Better at home by all honesty fo quicker results than waiting for the community.
    Now I really hope the response benefits you. Good luck!
    @AprilParrish
  12. AprilParrish , via OnePlus Nord N10 5G T-Mobile , May 7, 2021 :
    In the reading one will find after 14 consecutive days active in the community more options will become available to you.
  13. #12
