OP7 Pro Lagging!
  1. vijin john Cupcake Jun 25, 2019
    vijin john, Jun 25, 2019 :
    My One plus 7 Pro 8Gig Version is Sometimes lagging terribly!
    I noticed it Since I Started using the Built in App lock.
    it lags so bad that even during a Restart, The Boot Animation (2 White Dots Revolving around a Red one) Lags too!!!
    Anyone Having the same issue?
    PS:- My phone is only 10 Days Old
  2. TysonSW Froyo Jun 25, 2019
    TysonSW, Jun 25, 2019 :
    Haven't seen this on mine. What OS version are you on? Have you tried an factory reset?
    vijin john likes this.
  3. vijin john Cupcake Jun 25, 2019
    The latest one.
    have a lot of Backup downloaded for a Reset!!!
    can't afford a factory reset!
  4. TysonSW Froyo Jun 25, 2019
    Did you have the lagging problems from day one with the phone?
    If you didn't then there might have been some setting or app that you have installed that is causing this behavior. At least when it has finished booting.
    The boot problems can come from two things:
    1. Faulty hardware - if this was the case then you should have had problems from day 1.
    2. Something is wrong with the OS. This is usually solved with an factory reset.
  5. vijin john Cupcake Jun 25, 2019
    Not From Day 1.
    mostly From When I Started the built in App Lock
  6. TysonSW Froyo Jun 25, 2019
    Which apps have you locked down with the App Lock?
    Does the problem go away if you disable App Lock?
  7. vijin john Cupcake Jun 25, 2019
    Haven't Tried Disabling the app lock.
    but it doesn't lag now.
    it lags some times
    randomly
  8. TysonSW Froyo Jun 25, 2019
    Try to disable App Lock and see if the problem disappears.
  9. vijin john Cupcake Jun 25, 2019
    Alright.
    I'll keep you updated anyways
    TysonSW likes this.
