OP7 Pro Wifi Calling
  1. jdamo114 Cupcake May 22, 2019
    jdamo114, May 22, 2019 :
    Wondering if anyone has a solution for enabling VoWifi on the 7 pro. I followed the dial steps as instructed on the 6/6T, but unfortunately I don't see the VoWifi option in there.
    Anyone else having the same issue? not a big deal, just would like to have it enabled if possible. Thanks in advance!
  2. moigun Cupcake May 22, 2019
    moigun, May 22, 2019 :
    This depends on your carrier. who do you use?
    jdamo114 likes this.
  3. jdamo114 Cupcake May 22, 2019
    I have ATT, I used it fine on my Note 9. Thanks for the super quick response.
  4. moigun Cupcake May 22, 2019
    Samsung and Google seem to get whitelisted and this stuff just works, whereas, for example with Verizon, a BYOD Galaxy is capable and a BYOD oneplus isn't. I might just be something that isn't supported between OP and ATT
    If you're especially unlucky, neither side will cop to the issue and blame the other. :p
  5. jdamo114 Cupcake May 22, 2019
    Well, it's more of an issue where the option just isn't there. By default on the 6/6T there is no option. You have to go into the phone dialer and type "*#800*" this brings up a hidden menu where you can enable it.
    I'm guessing OP removed this option from OOS? I don't know.
  6. SpartanVissepo Eclair May 22, 2019
    SpartanVissepo, May 22, 2019 :
    This is from my 6 under SIM.
  7. jdamo114 Cupcake May 22, 2019
    Yeah, I checked there already, no option. It would be such an odd thing to remove. Unless they plan on adding it back in later?
  8. SpartanVissepo Eclair May 22, 2019
    That's weird, i myself I'm expecting a 7pro by mail tomorrow. I will keep you posted if find anything.
  9. misiokicio Donut May 22, 2019
    misiokicio, May 22, 2019 :
    same here, no option to enable it in logkit, definitely was there on 6t, and phone worked with volte and wifi calling,
  10. davepatterson2611 Jelly Bean May 22, 2019
  11. stephen.dunne Cupcake May 22, 2019
    stephen.dunne, May 22, 2019 :
    Works fine for EE-UK.
    VoWifi and VoLTE working out of the box, as is IPv6
  12. ravijain87 Gingerbread May 22, 2019
    ravijain87, May 22, 2019 :
    I'm using a unlocked version (from John Lewis) on ThreeUK. VoLTE and VoWifi seem to work however I have an issue that after a while the phone drops VoWifi back down to VoLTE and won't come back until I restart the phone. Wondering if anyone else has noticed this?
  13. misiokicio Donut May 22, 2019
    seems like only vodafone not working out of the box.. and need the manual switches to be on,
  14. davepatterson2611 Jelly Bean May 22, 2019
  15. jdamo114 Cupcake May 22, 2019
    So according to everyone here, seems it's there and working on the UK variant. So odd... Wonder if anyone from OP will respond?
