5
OP7Pro 90hz/stutter
  1. coldzage
    Froyo Aug 24, 2019
    coldzage , Aug 24, 2019 :
    The thing is... Is everyone experiencing this ONLY on Chrome? Because although it started when Chrome was updated, it doesn't seem to be limited to Chrome only. Unless simply having Chrome opened might cause symptoms elsewhere
  2. I1562550419333
    Cupcake Aug 24, 2019
    I1562550419333 , Aug 24, 2019 :
    Not only the chrome but the whole UI itself.. i am not saying that the phone is laggy, but it stutters from time to time.. specially if you use navigation gestures.. stutters is more obvious cos 90hrz is very smooth, so stutters is more noticeable... honestly disappointed, cos i was expecting it to be buttery on the gestures just like they are smooth on scrolling.. but its not... hope on android 10, it will be fixed.
  3. coldzage
    Froyo Aug 27, 2019
    coldzage , Aug 27, 2019 :
    Apparently more apps are being "reported" as broken regarding the 90hz over on reddit.
    So... The phones best feature is getting broken just before the 7T variants... Nice
  4. Ven96
    Froyo Aug 27, 2019
    Ven96 , Aug 27, 2019 :
    I'm not experiencing any stutters or lags except on the newest Chrome. Do some advanced troubleshooting and I believe your issue will be resolved. Try to wipe cache, look up XDA for OP7P Troubleshooting as well as on this forum. Generic troubleshooting may just fix your problem. It seems to me that this is a simple software bug that can be easily wiped out.
