OPO abruptly shuts down on 20-30% battery
  1. shalabhgupta
    Cupcake Feb 18, 2015
    shalabhgupta , Feb 18, 2015 :
    Hello All,
    After the recent update, I have observed that my OPO abruptly gets shut down when its on low battery i.e ~20-30%.
    Earlier I see the OPO running on 8-20% battery too, but now this doesn't happen.
    Has something changed in the latest release? I tried searching for a Power-Saver functionality but couldn't find one.
    Please assist.
  2. mohimirza
    Ice Cream Sandwich Feb 18, 2015
    mohimirza , Feb 18, 2015 :
    Are you on 11S or 12?
  3. shalabhgupta
    Not sure where to find it but here's the detail:
    Cyanogen OS Version: 11.0.XNPH05Q
    Android Version: 4.4.4
    Helps?
  4. arulkumaran
    Gingerbread Feb 18, 2015
    arulkumaran , Feb 18, 2015 :
    I face the same issue. I think, the software is not showing actual battery percentage. Not sure how to fix it
  5. mayanks
    Jelly Bean Feb 18, 2015
    mayanks , Feb 18, 2015 :
    try this...
    Switch off ur phone and charge it for 6-8 hours or probably over-night. It will be fine in the morning.
    Its a battery calibration issue.
    prathameshpuranik likes this.
  6. shalabhgupta
    Okay Mayank, I will try the suggested option, but its glad to know that many people have experienced it.
  7. nilay_jam
    nilay_jam , Feb 18, 2015 :
    Hi All,
    I am also experiencing the same issue! I tried charging it completely last night and the same thing happened today again.
    @mayanks : I will also try the method you suggested by keeping it plugged in all night long, hoping it works
    Thanks,
    Nilay
  8. imTSS
    KitKat Feb 19, 2015
    imTSS , Feb 19, 2015 :
    Its a battery calibration issue. Charge ur phone till 100% and then let it drain till it automatically switches off. Repeat this 2-3 times to re calibrate the battery.
    zeus.01.01.01.01 likes this.
  9. darkclouds
    Gingerbread Feb 19, 2015
    darkclouds , Feb 19, 2015 :
    Not to good idea to deep discharge(phone shutting down itself) the lion batteries, it degrades quicker.
    Best to continue normal usage with every time plugging in till 100% without interruption.
  10. zeus.01.01.01.01
    Lollipop Feb 19, 2015
    zeus.01.01.01.01 , Feb 19, 2015 :
    method by @tsshinde87 is correct and has been officially recommend by oneplus .
    imTSS likes this.
  11. imTSS
    KitKat Feb 19, 2015
    This way problem will never be solved
  12. babu1226
    babu1226 , Feb 19, 2015 :
    I am facing today the same problem ..
    Phone got shut down abruptly and i could not make it ON..I tried by connecting charger then the phone is ON showing 53% charging.
    Further i once again removed the charger ..to my surprise its get shutdown the movement i removed the charger.
    Kindly help to this issue.
  13. Aman Surana
    Honeycomb Feb 19, 2015
    Aman Surana , Feb 19, 2015 :
    @babu1226 it's a battery callibratoin issue, to fix this, charge your phone to 100%, then drain it, (till swtich off,) best way to do it would be play a game on full brightness.
    When the phone is off, charge it without turning it on, (this is important) after it's charged to 100 turn it back on, the problem should be fixed, if it doesn't repeat the process.
  14. babu1226
    Hi Thanks for the reply .. But the moment i remove the charger the phone gets shut down ...Even i tried charging making the phone ON connecting the charger.. To my surprise i charged around 30 min still showing the same battery % ..am panic
  15. Aman Surana
    @babu1226 dont remove the charger, charge it to 100% then take it out (i had the same problem)
    Then drian the phone, and follow the method.
  16. saint.soldier
  17. saint.soldier
    saint.soldier , Feb 19, 2015 :
    beware though...this fire up everything on your phone. your phone **might** get hot but this would solve the issue for sure.
  18. babu1226
    Hi How long did you charged the phone ... i have connected the charger for the past 40 mins ...but still i see the battery % remaining the same (ie, i connect the charger @ 53% ..after 40 mins of charging still it show 53% only ..that's my worry)
  19. Aman Surana
    @babu1226 it shows the same ( thats the issue, battery calibration )
    But it is charging, leave it for 2 hours, dont touch it :p thats what i did.
  20. babu1226
    Ok Thanks Bro ..I will do it!!
