2
Opo Belt Clip case
  1. sullyshine
    Froyo Oct 30, 2014
    sullyshine , Oct 30, 2014 :
    Wanted to share my oneplus one
    Ringke FUSION Case
    belt clip design with everyone, I am waiting on the prototype to be manufactured now, should have it in hands November 14.
    [​IMG] [​IMG]
    Manguman and aambrish like this.
  2. gmarch49
    Honeycomb Oct 30, 2014
    gmarch49 , Oct 30, 2014 :
    Nice, looks like a really solid design, when I get my hands on an OPO, i'd definitely be looking into a belt clip.
  3. slack2012
    slack2012 , Oct 30, 2014 :
    wow but that was horizontal may be you could add a belt clip that is rotatable 360 degree... I'm planning mine too using seido spring clip for note3
  4. risky1301
    Lollipop Oct 30, 2014
  5. actng
    Froyo Oct 30, 2014
  6. sullyshine
    Froyo Oct 30, 2014
    Yeah, Only reason for the big openings is "Cost", they knocked $30 off the proto price.... Since this is my first 3D design, I wanted to get the prototype in at lowest cost possible, to make sure everything fits and works properly. And added the angled reinforcements just give some more strength not that it needs a lot.
  7. shalinpatel
    Gingerbread Oct 30, 2014
  8. geier
  9. DavidHolden
  10. Flyer27
    Flyer27 , Oct 30, 2014 :
    A belt clip case would be great but I prefer vertical ones and that would be pretty clumsy for a phone this size.
  11. actng
    Froyo Oct 31, 2014
    actng , Oct 31, 2014 :
    you know what the best part of a belt clip case is?
    it tells you when you are fat. because the case will bend/break from your stomach/waist pushing on it! lol
    i lost 30 lbs after that.
    sullyshine likes this.
  12. Dr. Indest
    Lollipop Dec 30, 2014
  13. simonc76
    Jelly Bean Dec 30, 2014
  14. Manguman
    Honeycomb Jan 27, 2015
  15. Sept12Coo2
    Gingerbread Jan 27, 2015
    Sept12Coo2 , Jan 27, 2015 :
    Please make it where it can be clipped to places other than belts please. Nurses, and I'm sure other people need to put it other places...ie (scrub pockets)
    Manguman likes this.
  16. Manguman
    Manguman , Jan 27, 2015 :
    Any update
  17. Sept12Coo2
    Some nurses like the clip at the chest part of the scrubs so we can listen to music as a way to get through some stress full times, or as white noise.
  18. checcles
    Cupcake Apr 12, 2015
    checcles , Apr 12, 2015 :
    bump....anyone make a decent belt clip with otterbox style case? Working in the hospital and only wearing scrubs is a hassle at times. Thanks.
