OPO bootloop - Can't fix with factory reset
  1. BannWorthRulz
    Honeycomb Oct 22, 2014
    BannWorthRulz , Oct 22, 2014 :
    Fear not man there are many threads on that subject and people have solved it with little hassle. Just search bootloop fix in the search function and you will be on your way. Also maybe check out the xda developer forums they have a whole section dedicated to oneplus.
  2. pecana
    pecana , Oct 22, 2014 :
    Under recovery, "Backup", it will make a complete image of your current phone (except for internal storage) so you can always rollback to that state.
  3. mossy1963
    Jelly Bean Oct 22, 2014
    mossy1963 , Oct 22, 2014 :
    Searching helps
    https://forums.oneplus.net/threads/got-a-oneplus-problem-all-you-need-to-fix-it-yourself.155507/
  4. pecana
    Without getting crazy I would try to flash another ROM to check if it works. Maybe a nightly or a complete different rom like MIUI, but it is what I will try :)
  5. ChelseaDuck
    Gingerbread Oct 22, 2014
    ChelseaDuck , Oct 22, 2014 :
    I'm trying to flash ColorOs. I found the link on this forum. I'll let you know asap :)
  6. satty2k9
    Cupcake Oct 22, 2014
    satty2k9 , Oct 22, 2014 :
    Hi , I am very new to android .
    I got the same problem , when i go into recovery mode (Vol down and home button) i have wiped cache ,media everything but still my phone starts up and it ask me to choose language and then it restarts again?
    Anyone can help i would be very greatful.
  7. ChelseaDuck
  8. pecana
    Good Luck :)
    ChelseaDuck likes this.
  9. ChelseaDuck
  10. reyscott1968
  11. pecana
    Ok, Now I think you can install the stock ROM and work with it :)
    One done PLEASE make a backup from recovery for future needs :)
  12. ck064
    Eclair Oct 22, 2014
    ck064 , Oct 22, 2014 :
    Hello ChelseaDuck,
    I had the same issue yesterday, but found this info on here and xda.
    It is nothing you can fix with reboot, recovery and bootloader changes. You need to ensure you have TWRP recovery installed and then boot into recovery, go to Advanced and then Terminal Command.
    You can now input the simple command:
    make_ext4fs /dev/block/mm clip 15
    Which is taken from this article, which will fix the issue.
    http://www.androidpolice.com/2014/1...den-death-bug-results-neverending-boot-loops/
    It is related to a corrupt low level file section
    Hope this helps.
    James
  13. JuanL
    KitKat Oct 22, 2014
  14. Driver156
  15. RMuraj786
  16. kp1234
    Community Veteran Oct 22, 2014
    kp1234 , Oct 22, 2014 :
    This will fix it. I did it myself and helped someone else do it too.
  17. ChelseaDuck
    Gingerbread Oct 23, 2014
    kp1234 likes this.
  18. IdLoveToGetAOPO
    IdLoveToGetAOPO , Oct 23, 2014 :
    Glad to hear this, enjoy your One <3
    #38
    ChelseaDuck and kp1234 like this.
