(OPO)Install CM12.1 Dialer [Themable] in COS12.1
Did it work?
  1. Yes!!!
  2. No!!
  3. The dialer is not themable
Results are only viewable after voting.
  1. albertrix2000
    Gingerbread Nov 25, 2015
    albertrix2000 , Nov 25, 2015 :
    So ive seen many users (including me ) hated the new truecaller from cos12.1, i know this is an old topic and many of you already solve it by flashing the stock google dialer... The problem with flashing this dialer is that the stock dialer is unthemeable as many of you have noticed so it will look out of place while all your apps are themed, so i managed to find a dialer (not the stock one),and i found the cm nightlies one so it should theme as normal.
    Thanks to bigdave79 (I figured out how to make it work)
    *What it does?
    Deletes the truecaller apk, CM dialer and in call UI (DialerNext and INCallUINext) and replaces it with the dialer/call UI from the most recent CM 12.1 Nightly.
    *What you need?
    TWRP Recovery
    *Steps
    -Make a full TWRP Backup (System,Data,Boot)
    -Go to Wipe and do a Factory Reset not an advance wipe
    -Once your wipe is completed go to install and flash the "Dialer.zip"
    -Reboot system without cleaning dalvik or cache
    -Make all the startup process again (Cause you make a factory reset) and verify if you have the new dialer and not the truecaller one
    -Once you verified you have the cm nightlies dialer go again to TWRP then go to Restore and restore Data and boot (No system)
    -Now you have your themeable dialer and all your apps again!
    https://drive.google.com/file/d/0B9cqO53o0DjARUxOOXU0ckZ5MjA/view
    If it worked dont forget to thank! ;)
    Deactivated User likes this.
  2. Deactivated User
    Nov 25, 2015
    albertrix2000 likes this.
  3. Dr. Indest
    Lollipop Nov 25, 2015
    Dr. Indest , Nov 25, 2015 :
    Are you kidding me?
  4. albertrix2000
    Gingerbread Nov 27, 2015
    albertrix2000 , Nov 27, 2015 :
    Yeah im not kidding, This will mantain your system intact
  5. Dr. Indest
    Lollipop Nov 27, 2015
    Dr. Indest , Nov 27, 2015 :
    Noone sane will want to lose their data partition just to install a dumb dialer.
    jstepa likes this.
  6. albertrix2000
    You missed the step where you restore your data and all your DATA stays fine...
    Dr. Indest likes this.
  7. jstepa
    KitKat Nov 27, 2015
    jstepa , Nov 27, 2015 :
    No clue, do you? :confused:
  8. albertrix2000
    When you make a backup in TWRP you backed up the data, when this data is erased by a wipe it can be restored again
  9. jstepa
    KitKat Nov 27, 2015
    Still continuing while no cue, are we? :p
  10. albertrix2000
    What no clue?? All the steps are really clear!
  11. jstepa
    KitKat Nov 27, 2015
    This is why:
  12. albertrix2000
    He was saying that he would not loose his data(Apps and info) just for a dialer, but the steps i wrote clearly saves and restores all your data leading to not loosing anything
  13. aspherical
    Jelly Bean Nov 27, 2015
    aspherical , Nov 27, 2015 :
    If you're restoring the data position backup after the install, why wipe data at all?
    jstepa likes this.
  14. albertrix2000
    Because data will contain the old dialer while flashing and avoiding the cleansing of the caches will keep the new one
  15. aspherical
    That makes no sense. The dialer is a system apk. There may be dialer data stored in data, but restoring the backup is just going to put the old dialer data right back.
  16. albertrix2000
    My bad, yep... Well thats how it worked for me! Try for yourself your way and let me update the post ;)
  17. aspherical
    I would have if I hadn't already switched back to the CM nightlies.
  18. albertrix2000
    I tried to make it simple by just wiping factory without redownloading again cos, it should work both ways... By just restoring the data again
  19. albertrix2000
    Yeah that suck... I went to nightlies to try cm13 but i really love the cos per app themer and i dont want to flash capps because it flashes againg the truecaller dialer
  20. albertrix2000
    Great to hear it worked! :)
