5
Network/Connectivity
OPO On Screen nav/ hardware buttons not working
  1. Airlacks Cupcake Sep 10, 2017
    Airlacks, Sep 10, 2017 :
    Having this problem too. Looks like it's getting worse. Defective area expanding from bottom up. I guess it's really an hardware issue?
  2. aswinthomas08 Cupcake Nov 27, 2017
    aswinthomas08, Nov 27, 2017 :
    Facing the same problem. Hard buttons stopped working few months back. Using soft buttons now. Not faced an issue with the bottom Nav bar till now. Just wanted to see any solution is arising for the issue.
  3. bmaz121 Froyo May 30, 2019
    bmaz121, May 30, 2019 :
    OK, Now if you are having this problem it's because the tempered glass is blocking some signals to the digitizer and sensors. The correct way to fix this is to order a Mic replacement which has new sensors and are better than the original and a new screen. These come in about 3 weeks from China and there are plenty of YouTube fix your OnePlus One screen videos to help getter done. Keep your OnePlus One. Under $50 bucks. This phone is easy to work on. Just be careful removing the back battery cover. While your at it clean the joints where the case meets the cover, the Mic holes top and bottom and the speaker areas of dust and finger oil. If your smart you'll order the screen already on the frame assembly.
