OPO recent fast battery draining
  1. grahamcurtis1 Cupcake Aug 19, 2017
    grahamcurtis1, Aug 19, 2017 :
    About two weeks ago my OPO suddenly started draining when in standby at the rate of 7-8% per hour (instead of the previous 2%). The battery setting shows that the only battery usage is
    Cyanogen Mod System,
    Cyanogen Account,
    Google Play Services,
    Android OS
    - no others - in particular no apps. It looks like systems are working in the background.
    Cyanogen OS 13.1.2-ZNH2KAS3P0-bacon
    Android 6.0.1
    The systems update on the phone is showing fully updated
    Any suggestions??
    peralex84 likes this.
  2. arjanvlek Honeycomb Aug 19, 2017
    arjanvlek, Aug 19, 2017 :
    The Cyanogen Account is known for being problematic. Can you try to go to Settings -> Accounts -> Cyanogen and sign out of your account?
  3. grahamcurtis1 Cupcake Aug 19, 2017
    Thanks. Unfortunately I can't liaise with my Cyanogen Account. Each time I try I get a communications error message. I believe this may be because CyanogenMod has closed. If I try to long on via a web page on my computer - it can't find the page. Should I remove my Cyanogen mod account?
    The Cyanogen Update tracker confirms I have the latest version of CyanogenMod.
  4. Mykson Ice Cream Sandwich Aug 19, 2017
    Mykson, Aug 19, 2017 :
    Cyanogen is dead, you won't need your account again and there won't be any updates anymore.
    Also don't confound Cyanogen Inc., CyanogenOS and CyanogenMod.
    Here are some things you should try:
    • Remove your Cyanogen and every account you don't need
    • Close all your apps
    • Reboot your phone
    • Delete all apps you don't need
    • Update all apps via Play Store
    • Wipe cache in storage settings and recovery
    • Delete all files and folders from your phone you don't need anymore with a file manager (ad-folders and so on)
  5. entax Eclair Aug 19, 2017
    entax, Aug 19, 2017 :
    Hi, I have the same problem. I've tried to suppress cyanogen apps, but it seems to be locked...
  6. remedy KitKat Aug 19, 2017
  7. entax Eclair Aug 20, 2017
    entax, Aug 20, 2017 :
    Thanks for the advice, but I'm not very used to solve problems wiping the phone. Maybe I'll try oxygen os, who knows, it may be good enough.
  8. Gonzo01 Lollipop Aug 20, 2017
    remedy likes this.
  9. Tallipia Gingerbread Oct 15, 2017
    Tallipia, Oct 15, 2017 :
    I have the same problem with my opo. Cyanogen account is draining my battery and I don't know what to do about it... I can't delete the account because the site is down and I have no option to remove account on my phone. What can I do???
  10. Mykson Ice Cream Sandwich Oct 15, 2017
    Mykson, Oct 15, 2017 :
    Aren't you able to delete/disable the Cyanogen account from settings, accounts?
    Go through all your system apps (apps, three dots, show system apps), maybe you find some Cyanogen tasks that are running in the background. Stop and disable them.
  11. Tallipia Gingerbread Oct 16, 2017
    Tallipia, Oct 16, 2017 :
    No I can't disable the account, the option to disable is greyed out. Screenshot_20171016-095725.png
  12. Mykson Ice Cream Sandwich Oct 16, 2017
    Mykson, Oct 16, 2017 :
    But in settings, accounts?
    Where your Google and E-Mail accounts are.
  13. Tallipia Gingerbread Oct 19, 2017
    Tallipia, Oct 19, 2017 :
    No, there is no option there. For other account I have options to remove account but for this one I don't.
  14. vintcf Jelly Bean Oct 31, 2017
    vintcf, Oct 31, 2017 :
    same issue here, have you solve it?
  15. SinisterTaichou Cupcake Nov 10, 2017
    SinisterTaichou, Nov 10, 2017 :
    Ok so I also have the same problems you guys are having with an additional issue, i can't even open the Cyanogen account in the setting app, the setting app crashes every time.
    i was doing some reading, and from the privacy section you can block the Cyanogen account from access to WIFI. I have done so and will monitor to provide feedback in a few days.
  16. SinisterTaichou Cupcake Nov 10, 2017
    well didn't plan on updating this soon but no luck, after full charge lost 10% battery life in less than 45 mins of standby time. so seems the only way to get out of this might be to remove this OS.
  17. dniz.dz Cupcake Nov 12, 2017
    dniz.dz, Nov 12, 2017 :
    So, I've found way to disable cyanogen mod account.
    here's the proof.
    anyway the problem is a bit simple.
    you cant stop it because cyanogen is a adminstator service tk manage your device, to stop the service, you've just need to stop using cyanogen account as your device admin.
    simply use this simple steps.
    1. go to setings
    2. go to apps
    3. click three dots on top most corner, and show system
    4. search for "Cyanogen Account"
    5. click another 3 dots and uninstall
    6. it'll say error, this is an admin blablabla.
    7. just untick, and tick find my phone (by Google App)
    8. repeat "step 5" until you can stop and disable it.
    goodluck!
    Regards,
    Dennis. ECIH.
    remedy likes this.
  18. Captchaplus Cupcake Nov 14, 2017
    Captchaplus, Nov 14, 2017 :
    its quite possible the battery is worn although if it is a software problem try disabling some of cyanogens services, factory reset or install a new rom. factory reset will probably work but cyanogen is dead m8
  19. uday209 Cupcake Nov 17, 2017
    uday209, Nov 17, 2017 :
    I am also facing the same battery drain issue and My phone is restarting automatically several times.
  20. arjanvlek Honeycomb Nov 17, 2017
    arjanvlek, Nov 17, 2017 :
    That means it's time to replace your battery, or upgrade to a new phone.
