5
[OPO] ROM Purity 6.0.1
  1. pikota
    Marshmallow May 9, 2016
    pikota , May 9, 2016 :
    Já está a bombar. :D
    suskisunami likes this.
  2. PCesar.Cercal
    KitKat May 9, 2016
    PCesar.Cercal , May 9, 2016 :
    Eu tenho o, mas logo já meto aqui. Mas se fores ao G+ no tópico da Purity vais encontrar o post da ROM e ao abrires tens o changelog
    BrunoNRG likes this.
  3. PCesar.Cercal
    KitKat May 9, 2016
  4. suskisunami
    Gingerbread May 9, 2016
    suskisunami , May 9, 2016 :
    Acho que tenho que dar mais uns ciclos de carga porque isto hoje não me deu grande SOT, mas deu me para o dia com 1h de SOT algo estranho :confused: e mais uma coisa a app dos documentos agora não me deixa instalar apks deixa de responder :confused: será que tenho que instalar tudo de novo ?
  5. PCesar.Cercal
    KitKat May 9, 2016
    Por aqui tudo normal
  6. PCesar.Cercal
    KitKat May 9, 2016
    Purity 08/05 OnePlus One - Bacon
    https://basketbuild.com/filedl/devs.../Bacon/Purity/purity-6.0.1-20160508-bacon.zip
    If you like Dario's work, support him! https://www.paypal.me/dariosf
    I am not responsible for bricked devices, lost data, etc. Flash at your own risk!
    CHANGELOG
    Purity 08/05
    Updated sources to android-6.0.1_r43 tag
    Build:
    Added DataUsageProvider to the build
    Merge tag 'android-6.0.1_r43' into HEAD
    build: Fix manual invocation of aar targets.
    build: Make sure to check for variable definition during execution.
    build: allow to set a consumer proguard file
    DeskClock:
    DeskClock: Fix view animator race condition
    Revert "Merge tag 'android-6.0.1_r22' of https://android.googlesource
    Revert "Revert "Import translations. DO NOT MERGE""
    Device_lge_d855:
    d855: add assertions on stock 5.0 or higher
    recovery: use "QC_IMAGE VERSION_STRING" as a unique version indicator
    recovery: more descriptive flash failure message
    recovery: fix parsing multiple baseband versions
    d855: add assertions on baseband version
    Device_lge_g3-common:
    g3: init: set perf mode in recovery during installs
    g3: enable adaptive lmk
    g3: init: update init.g3*.rc
    g3: init: move power items to separate file
    g3: fix nfc device sepolicy
    g3: update permissions
    g3: Set bluetooth operating voltage
    Device_oneplus_onyx:
    onyx: Update bluetooth sepolicy
    External_toybox:
    toybox: Do not install a symlink for traceroute6
    Frameworks_base:
    batteryservice: Use Alpha channel for segmented LED power level
    SystemUI: Update cached weather data when temperature unit changes
    perf: Send the process name and pid for launch boosts
    SysUI: Make sure LLS focus is false when unlocking
    Lockscreen : Bunch-o-fixes
    Add new options for call waiting response in InCallUI
    SystemUI: bail out of recents-to-home animation when losing focus
    fw: Provide system context to EnableAccessibilityController.
    Themes: Expose manifest styles for framework activities
    Revert "Themes: Expose manifest styles for themes"
    SystemUI: LiveDisplay is not translatable
    server: modify network stat plugin framework
    SystemUI: implement properly saving tile locations
    Fix revert build breakage
    pms: Skip reinstall of prebundles correctly per user.
    Partially revert "Merge tag 'android-6.0.1_r22' of https://android.go
    batteryservice: Add support for segmented power LEDs
    SystemUI: avoid lock screen shortcut picker crash
    SystemUI: remember deleted custom tiles
    Merge tag 'android-6.0.1_r43' into android-m
    Settings: defer DEV_FORCE_SHOW_NAVBAR query to CMSettings
    Lockscreen shortcuts: don't allow specific activities
    keyguard: Allow disabling fingerprint wake-and-unlock
    nms: Only generate LED colors if the device has a multicolored LED
    Revert "SettingsLib: Add back accidentally removed translations"
    Frameworks_native:
    Frameworks_opt_telephony:
    SubscriptionController: properly detect when MSIM has 1 SIM
    Revert "SubscriptionController: don't lock sms prompt state"
    Add new networktypes in sim status
    Single digit MMI codes cause CTS to fail
    Fix bug in CallManager unregisterForPhoneStates()
    IncallUI:
    Kernel_asus_grouper:
    Revert "Revert "Disable crc for performance""
    Revert "add extra free kbytes tunable"
    Disable zcache
    Defconf update
    ALSA: hrtimer: Fix stall by hrtimer_cancel()
    Kernel_lge_g3:
    clocksource: Extract max nsec calculation into separate function
    sched_clock: Backport high-resolution support
    msm: kgsl: Fix idle timer sysfs after removing references to HZ
    ipv4: Don't do expensive useless work during inetdev destroy.
    netfilter: x_tables: fix unconditional helper
    USB: cdc-acm: more sanity checking
    usbnet: cleanup after bind() in probe()
    Merge remote-tracking branch 'caf/LA.BF.1.1.3_rb1.13' into android-m
    Kernel_oneplus_onyx:
    timeconst.pl: Eliminate Perl warning
    onyx: add CONFIG_HZ=300
    ALSA: usb-audio: avoid freeing umidi object twice
    ALSA: timer: Fix race among timer ioctls
    ALSA: timer: Fix double unlink of active_list
    ALSA: timer: Harden slave timer list handling
    pipe: limit the per-user amount of pages allocated in pipes
    Settings:
    Settings: Don't enable proximity on wake by default
    Add option to select temperature unit
    Update power control widget preview image.
    Settings: sync qs invert color with color inversion in Settings
    Partial revert "Settings : Add per app internet/data control"
    Protected apps: fix rotation states
    LockPatternView: persist state across rotates
    LLS: Load title and summary from ext. package if avail.
    Settings: Make sure to rebuild on app entries loaded.
    Settings: fix backlight illumination wrong summary
    SoundRecorder:
    Screen configuration changes did not initialize menu button
    SoundRecorder: Fix SD card storage problem
    Automatic translation import
    System_core:
    Use fsck.f2fs -a instead of -f for faster boot
    Revert "Revert "fs_mgr: let fsck.f2fs actually attempt a fix""
    rootdir: Remove cpufreq mode settings
    Telephony:
    Support for showing remaining retries for PERSO lock
    Revert "Single digit MMI codes invalid."
    Apply correct theme color to USSD progress dialog.
    Trebuchet:
    Trebuchet: send metrics directly when possible
    Trebuchet: Add runtime storage perm check for wallpaper picker
    Prevent widget previews from showing empty images.
    Use bitmap filtering for shrinking app icons
    Prevent crash when exiting grid size fragment
    Vendor_cmsdk:
    cmsdk: Pass the process name and pid for launch boosts
    Set a default temperature unit
    Revert "Allow to ignore presentation indicator of outgoing calls [1/3]"
    QS: Make themes a first class citizen again
    cmsdk: Fix CTS Failure due to testDumpProtected
    cmsdk: add persisted key value for status bar tiles
    cmsdk: Add allowViaWhitelist to LLS_MANAGER_ACCESS_PRIVATE
    cmsdk: Add support for segmented LEDs
    cmsdk:mad:hide protected variable
    CMSettings: intercept Settings calls to DEV_FORCE_SHOW_NAVBAR
    cmsdk: Fix PerformanceManagerTest expectations.
    cmsdk: include our own consumer proguard rules
    cmsdk: set minsdk to api level 4
    cmsdk: Fix warning from 64-bit clang
    Vendor_purity:
    cm: Add SE policy for iop service
    Add oneplus2
    pikota and BrunoNRG like this.
  7. BrunoNRG
    Ice Cream Sandwich May 10, 2016
    BrunoNRG , May 10, 2016 :
    Depois de se criar a conta e copiar o api para as definições é preciso fazer mais alguma coisa, onde é que a temperatura aparece?
  8. PCesar.Cercal
    KitKat May 10, 2016
    PCesar.Cercal , May 10, 2016 :
    Não, colocas o api e depois ele ativa
  9. suskisunami
    Gingerbread May 10, 2016
    pikota and PCesar.Cercal like this.
  10. pikota
    Marshmallow May 10, 2016
    pikota , May 10, 2016 :
    Ainda não posso garantir isso, estou no segundo ciclo de carga. ;)
  11. BrunoNRG
    Ice Cream Sandwich May 11, 2016
    BrunoNRG , May 11, 2016 :
    Activa onde, na barra de estado ou por widget?
    Já meti o api mas não aparece nada, será de estar a usar o nova launcher?
  12. PCesar.Cercal
    KitKat May 11, 2016
    PCesar.Cercal , May 11, 2016 :
    Não, em principio assim que colocas ele fica ativo. Vão confirmar no provedor se está ativo
  13. suskisunami
    Gingerbread May 11, 2016
    suskisunami , May 11, 2016 :
    Depois diz qualquer coisa !
  14. PCesar.Cercal
    KitKat May 11, 2016
    Ontem falei com um opiniano no G+ que é testador d ASParadox 3.0, e diz que é uma bomba.... Estou mesmo curioso
    pikota likes this.
  15. BrunoNRG
    Ice Cream Sandwich May 12, 2016
    BrunoNRG , May 12, 2016 :
    Tá aqui qualquer coisa a falhar... :p A informação de temperatura, depois de activares com a chave api, no teu OPO, aparece onde, barra de estado ou em algum widget? Eu não uso o laucher trebuchet nem nenhum dos widgets que vem com a rom.
  16. PCesar.Cercal
    KitKat May 12, 2016
  17. pedroware
    Cupcake May 12, 2016
  18. pikota
    Marshmallow May 12, 2016
    pikota , May 12, 2016 :
    Não necessitas, só rom e gapps. :)
  19. pedroware
  20. pikota
    Aqui na Purity, está muito boa. :)
