5
[OPO] ROM Purity 6.0.1
  1. pikota
    Marshmallow Apr 10, 2016
    pikota , Apr 10, 2016 :
    Vai deixando aqui os links para o pessoal que não encontram esta ROM. O G+. ;)
    #61
  2. PCesar.Cercal
    KitKat Apr 10, 2016
    PCesar.Cercal , Apr 10, 2016 :
    Eu fui banido, terá que ser o mentor deste tópico ou outro
    #62
  3. pikota
    Fizeste das boas. :D
    Não consegues deixar aqui nenhum link para eu postar aqui?
    #63
  4. sometheway
    Ice Cream Sandwich Apr 10, 2016
    sometheway , Apr 10, 2016 :
    Acho quem está com esta ROM não precisa de links, tem a OTA da ROM e o update está disponível para download.
    #64
  5. mateuspt
    Honeycomb Apr 10, 2016
    mateuspt , Apr 10, 2016 :
    Purity 09/04 OnePlus One - Bacon
    https://basketbuild.com/filedl/devs.../Bacon/Purity/purity-6.0.1-20160409-bacon.zip
    If you like Dario's work, support him!https://www.paypal.me/dariosf
    I am not responsible for bricked devices, lost data, etc. Flash at your own risk!
    CHANGELOG
    Updated sources to android-6.0.1_r24 "MHC19Q"
    Build:
    envsetup: Always look up JAVA_HOME path
    Preventing default locale from being overridden because of buildinfo.sh
    qcom: Allow usage of default QC HAL paths
    build: add cmts config to global build
    Device_oneplus_onyx:
    onyx: Fix MIC mute issue when using Hangouts
    External_sqlite:
    Remove redundant fdatasync flag
    Updated sqlite library to version 3.11.1
    Kernel_asus_grouper:
    timeconst.pl: Eliminate Perl warning …
    pipe: Fix buffer offset after partially failed read …
    pipe: iovec: Fix memory corruption when retrying atomic copy as non-a… …
    KEYS: Fix handling of stored error in a negatively instantiated user key
    sched: disable GENTLTE_FAIR_SLEEPERS for better performance on Android
    Kernel_lge_g3:
    Kernel_oneplus_onyx:
    Purity localversion
    Frameworks_base:
    SysUI: Add event logs for live lock screen interactions …
    NetworkTrafficMonitor: update …
    Fix incorrect behavior for statusbar and quicksettings panel …
    Don't take screenshots for tasks that are being cleared …
    Make sure emulated storage index preceed non-emulated ones and succee… …
    Fix: the label "customize" is not updated after changing language …
    Lockscreen target fixes …
    Fix typo in RankingHelper.
    SettingsProvider: fix build for volume adjust sound to be overlayed …
    SettingsProvider: Allow default volume adjust sound to be overlayed. …
    com.android.cts.appsecurity.AdoptableHostTest may trigger below dead …
    Automatic translation import
    Revert "Frameworks: Restart last task if last task is dead" …
    Purity is starting/upgrading …
    Power menu: Change color of volume selector to material green
    Lockscreen : Fix bottom area visibility
    Keyguard: don't refresh ui when screen off …
    Frameworks: Restart last task if last task is dead …
    audio: Don't play sound effects if stream is muted …
    SystemUI: show visualizer in shade-locked view …
    Re add missed import
    Speed up notification panel pulldown animation when called externally …
    Fix for inconsistent Show/Hide Internal storage option when EXTRA_SHO… …
    Fix dead lock in Tethering state machine …
    SysUI/LLS: Slide panel out when collapse called …
    Add Weather Content Provider [5/5]
    fw: Respect new cmsdk sdk class directory. …
    Framework changes for resetting data usage statistics …
    NetworkManagement: Add ability to restrict app WiFi background data a… …
    SystemUI: ensure volume record exists before showing notification …
    MountService: ensure VolumeRecord with UUID exists before modifying …
    Implement left swipe on lockscreen …
    LLS: Use window attachment callbacks …
    LLS: Add LiveLockScreenController
    Fix ownership for files/folders created by ExternalStorageProvider on… …
    SystemUI: remove deleted broadcast receiver …
    pm: Don't call into AppSuggestManager before service available. …
    Don't block wake locks for required always-on system apps …
    Frameworks AppOps: Enable MODE_IGNORED for OP_WAKE_LOCK …
    SystemUI: stop hiding hotspot & color inversion tiles …
    Frameworks_opt_telephony:
    Volte: set volte feature enable in ImsManager when Volte service is u… …
    telephony: Only set prompt enabled if available subscriptions > 1. …
    Use registerForAvailable when device is encrypted only for RIL versio… …
    telephony: Workaround default sms sub id not being set. …
    Fix LTE attach issue due to wrong initial attach profile. …
    telephony: Add oldril feature setPrefNwTypeOnUnsolConnected.
    Settings:
    Fix end padding of summary text for dialog is too narrow …
    Fix user photo popup layout for RTL …
    Add Up button in Status settings …
    Add explanation for customizing apps …
    Settings: use ActivityManager method for requesting bug report …
    Settings: Disable and hide refresh button on power usage detail. …
    NetworkTrafficSettings: update
    DevelopmentSettings: Synchronize USB connection data state …
    Settings: Use correct LOW_POWER_MODE_TRIGGER default …
    AppOps: Don't show option to restrict network usage for platform sign… …
    Improve cellular data strings
    Settings app Data Usage UI enhancements …
    LLS: Add config for showing LLS settings at top …
    Add Weather Content Provider [2/5] …
    Settings: add marquee to Device administrators screen
    LLS: Add LiveLockScreenSettings to ENTRY_FRAGMENTS
    Settings: implicitly link to lls settings …
    LLS: Use LiveLockScreenManager for selecting LLS …
    Settings: Fix one-time vibration intensity restore …
    Settings: reflect/inform user of disabled wakelock appop …
    System_core:
    sched_policy: zero proc_name buffer before populating
    Telephony:
    Phone: Sprint MWI Quirk: Phantom message wait indicator workaround
    Vendor_purity:
    sepolicy: allow platform apps to execute render scripts
    Actually have checkapi-cm match against prior release. …
    Prepare for api level 6. …
    Add Weather Content Provider [3/5] …
    Fix typo
    cm: Add further verbose messaging for api breaking changes. …
    LLS: Add live lock screen service [3/4] …
    LatinIME: Refresh remaining dictionaries …
    Revert "Revert "Don't build Development package"" …
    PurityU2D fix permissions
    purity-6.0.1-20160409-bacon.zip :: BasketBuild Download
    basketbuild.com
    #65
    lusipt and pikota like this.
  6. lusipt
    #66
    pikota likes this.
  7. pikota
    Entre esta e a do jgcaap, quais as diferenças notórias?
    #67
  8. lusipt
    lusipt , Apr 10, 2016 :
    Há muito que não uso a do jgcaap não sei como está a dele, esta está perfeita para o meu gosto, simples e suave :D
    #68
    pikota likes this.
  9. pikota
    A fazer download, vou testar. :)
    #69
  10. PCesar.Cercal
    KitKat Apr 10, 2016
    Até não, se fores ao G+ e verificares na secção onde está a rom de dia 28, podes ver o que postei.
    Acho que não disse nada ofensivo ou que colocasse em causa o bom trabalho desenvolvido...
    #70
  11. PCesar.Cercal
    KitKat Apr 10, 2016
    Para mim são as duas melhores roms, logo depois vem a do tugapower.
    Agora falta testar a COS13
    #71
  12. pikota
    Marshmallow Apr 11, 2016
    pikota , Apr 11, 2016 :
    Depois de quase 24 horas com a Putity vou deixar o meu feedback. :)
    1º Captação de rede brutal, está ao nível da do jgcaap ou melhor.
    2º Fluidez, estabilidade e autonomia.
    3º Nenhum problema detectado.
    Cliente satisfeito. :D :p
    #72
    lusipt and PCesar.Cercal like this.
  13. PCesar.Cercal
    KitKat Apr 11, 2016
    #73
    pikota likes this.
  14. lusipt
    Ice Cream Sandwich Apr 11, 2016
    lusipt , Apr 11, 2016 :
    Está mesmo uma maravilha :D
    Adoro a simplicidade e a fluidez, um mimo.
    #74
    PCesar.Cercal and pikota like this.
  15. pikota
    #75
  16. Superdragon11
    Donut Apr 11, 2016
    #76
  17. VitorMSA
    Gingerbread Apr 11, 2016
    VitorMSA , Apr 11, 2016 :
    Boas a todos. Partilho da dúvida do @Superdragon11 sobre as atualizações e também gostaria de saber se suporta o F2FS em todas as partições.
    #77
    Superdragon11 likes this.
  18. PCesar.Cercal
    KitKat Apr 11, 2016
    PCesar.Cercal , Apr 11, 2016 :
    As atualizações são quando necessário e sem pressa.
    Em relação ao f2fs não julgo possível
    #78
  19. sometheway
    Ice Cream Sandwich Apr 12, 2016
    #79
  20. PCesar.Cercal
    KitKat Apr 12, 2016
    #80
