[OPT] 2.1.1 Issue with Battery - GMail App
  1. vikasr1234
    Froyo Oct 19, 2015
    vikasr1234 , Oct 19, 2015 :
    After the 2.1.1 upgrade, battery life has degraded by 3-4 hours on my normal usage. Here is what it shows in the battery usage - gmail has started topping the chart after this upgrade. Is it happening for others as well? Any fix?
  2. Sudish Patil
    Froyo Oct 19, 2015
    Sudish Patil , Oct 19, 2015 :
    The photo attached shows a very impressive battery life dude!!!:D:D:D
    But even I have the same issue. After 2.1.1 update, the battery life has noticeably gone down. Also, sometimes the phone has started heating up without any heavy usage(It, the heating is between warm and hot) and when heated up, the battery depletes very fast.
  3. siddh4rth
    Froyo Oct 19, 2015
  4. vikasr1234
    Froyo Oct 19, 2015
    It was better by atleast 4 hrs.. So I am being greedy here... ;)
    Seriously.. 2.1.1 upgrade has messed up the battery life.
  5. vikasr1234
    Froyo Oct 19, 2015
    If it continues like this, yes I will. But with GMail so far, I was getting 4 more hours till 2.1.1 happened. Maybe shouldn't upgrade that fast.
  6. Thanasis Kalatheris
    Eclair Oct 19, 2015
    Thanasis Kalatheris , Oct 19, 2015 :
    Do you have an imap or pop personal account linked with the gmail app other than the Google email? Cause I have one and it syncs constantly without a reason. Oxygen is full of bugs so don't be surprised this is happening
  7. Svelte
    Cupcake Oct 20, 2015
  8. Svelte
    Svelte , Oct 20, 2015 :
    By the way, getting like 6 hours of battery compared to 10, and Google Play Services and Gmail are at 35% and 34% respectively.
  9. TlathamXmahtalT
    KitKat Oct 20, 2015
  10. Svelte
    I don't see app permissions for Gmail nor Google Play.
    Baymax likes this.
  11. TheManDroid
    Honeycomb Oct 20, 2015
    TheManDroid , Oct 20, 2015 :
    You can install an Xposed module called 'AppOpsXposed'. the module will allow you to control the individual permissions for an app.
  12. TheManDroid
    6 Hours from 100% to 0 or 6 hours SOT?
  13. Svelte
    6 hours with barely any screen usage, compared to 10 with medium screen usage. Also, I haven't rooted this phone yet so no xposed - my point was that obviously 2.1.1 broke something and is causing battery drain because I didn't have this problem before the update.
  14. Svelte
  15. TheManDroid
    Have you tried to wipe/clear cache from recovery?
  16. Svelte
    Just did it, I doubt it will work though. I'll report back in the morning.
  17. abhishekverma590
    Froyo Oct 20, 2015
    abhishekverma590 , Oct 20, 2015 :
    I was so angry with this update I decided to flash AK kernel on my OPT. AK kernel does a good job in battery optimisation. I would recommend to try it.
    Makke375 likes this.
  18. Lchow
    Eclair Oct 20, 2015
    Lchow , Oct 20, 2015 :
    You must have a pop3 mail account syning every 5 minutes or so, change it to syn every hour and you will find the battery life increase drastically.
  19. Svelte
    It syncs every thirty minutes and settings haven't been changed since before the last update - and I don't get a ton of email.
  20. molle65
    Froyo Oct 20, 2015
    molle65 , Oct 20, 2015 :
    Have the same problem on my Samsung S4
