optimized charging not working via OnePlus 7 Pro Mirror Gray
  1. LeeUyhong , via OnePlus 7 Pro Mirror Gray , Apr 19, 2021 :
    after i updated oos11 first day optimized charging function is working properly (80% stop charging) but next day till now (3days) optimized charging function is not working (charging 100% not 80% stop).
    vbz89 likes this.
  2. Tokolozi
    Most Original Avatar Apr 19, 2021
    Tokolozi , Apr 19, 2021 :
    Do you have an alarm set, AFAIK this is one of the main things it uses to "stop" charging at 80%.
    McJader and Aaron2017 like this.
  3. Last edited: Apr 20, 2021
  4. vbz89
    Froyo Apr 26, 2021
  5. cdenigris
    Eclair May 4, 2021 at 3:15 PM
    cdenigris , May 4, 2021 at 3:15 PM :
    I bought a OnePlus 8t and optimized charging does not work on any charger other than the original OP charger. I plug it in at night and wake up and its either 58 or 78 % or something like that. I have set alarms and all and it does not adapt. I have tried turning off optimized charging and that is the only time I wake up to 100%. I also do not live the same schedule every day which is a major oversight of this feature. It needs an adjustment to manually set what time you need it to be 100%, I thought the alarm would help with that but no go. Anyone else having a similar issue?
  6. J1620143700590
    Cupcake May 4, 2021 at 4:56 PM
    J1620143700590 , via OnePlus 8T , May 4, 2021 at 4:56 PM :
    I have the same issue in my 8T. The optimized charging worked for about one week when I first got it. Stopped working afterwards, tried turning on and off, setting sleep alarms, restarting phone. My sleep schedule is also relatively consistent.
