5
[OPX 2.2.1|blu_spark-kernel|Tweaks]
stay with OPX and wait for MM or buy OP3 with the same faith like OPO/OP2/OPX ?
Poll closed May 25, 2016.
  1. Stay with OPX and wait MM
    5 vote(s)
    83.3%
  2. Buy OP3 with "risks"
    0 vote(s)
    0.0%
  3. No more OP stuffs!
    0 vote(s)
    0.0%
  4. Stay with OPX also buy OP3
    1 vote(s)
    16.7%
  1. SapilautX
    Ice Cream Sandwich Apr 22, 2016
    SapilautX , Apr 22, 2016 :
    ✴ CUSTOMs ➕ MODs ✴
    OK neng sis, mas broo ❗
    bagi yg masih bertahan dengan stock ROM oOS 2.2.1 LP 5.1.1 atau iseng coba custom kernel ◀BLU_SP⭐RK dan custom APPs & MODs ▶
    sembari menunggu official oOS 3.x marshmallow (maybe) ? whatever.... just check this out!
    Rules & Conditions :
    ▶▶this is not for beginners, but if you're happy messing up with your device, so you're all welcome! do at your own risks ❗ ◀◀
    1) always backup before messing up with your device ❗
    2) saya tidak akan menjawab pertanyaan2 seperti... "apa itu custom kernel, gmn cara unlock bootloader, nge-root, nge flash, dsb dsb" silahkan anda googling sendiri..sudah banyak tutorial dan penjelasan mengenai hal2 tsb ❗
    3) saya tidak akan menjawab segala pertanyaan OOT (out of topic) ❗
    4) kalau pertanyaan blm dijawab tandanya saya lg sibuk mencari jati diri, eh mencari uang! i'm working and not always online all the time! *budayakan googling ❗
    5) RTS (Resiko Tanggung Sendiri) ❗
    1st stage : messing up with custom kernel ;)
    Status OPX :
    √ oOS 2.2.x LP 5.5.1 Onyx ver. only
    √ TWRP blu_spark onyx v29 / latest ver. v35
    √ SuperSU Pro 2.65 / free 2.65 / latest ver.
    √ Custom Kernel blu_spark ver.123 / latest ver. r137
    √ Kernel Adiutor 0.9.9.4 (playstore)
    ▶Download Links : (Custom Kernel + TWRP)
    ▶Pra-syarat :
    √ Unlocked bootloader
    √ Rooted (superSU 2.65 / latest ver.)
    ✔ *TWRP
    Note :
    >Developer option: ON
    >Oem unlock: ON
    *Additional: USB debugging ON + Backup (system,boot,data) jika sewaktu-waktu "diperlukan". if you don't, so take at your own risk!
    OK Let's start ❗
    ◀CPU VOLTAGE ▶
    ~ Undervolting (UV) -100 (default 825mv)
    ~ cek dulu pvs anda (E1003 sama rata kayanya pvs12 bin) bisa UV sampai -100mv ~ -120mv, tapi hati2 bisa turun berook nanti hehe atau kurang tenaga.
    √ results -100 : so far sangat stabil tidak ada masalah (reboots, hangs, dll). panas jauh berkurang, battery jauh lebih irit dalam multitasking, dsb.
    *SOT up to 5 jam 30 menit (tergantung pemakaian, settingan, dan cara pakai user).
    ◀CPU GOVERNOR▶
    ~ blu_active (default)
    pada dasarnya modifikasi dari "interactive". set Max 2265Mhz, set Min 300Mhz. klik CPU Governor Tuneables utk setting..
    ~ hi_speed freq :
    1497000
    ~ input_boost_freq :
    960000
    *lainnya biarkan default.
    ◀CPU Hotplug▶ (optional)
    ~ Max cores screen off :
    saya tetap biarkan default (2) namun jika ingin setting ke (1) silahkan saja, utk results nanti saya jelaskan di kesimpulan akhir.
    *yg lainnya biarkan default
    ◀GPU GOVERNOR▶
    ~ performance
    Max 578Mhz (default msm_adreno_tz Max 578Mhz, cuma sering statis di 300Mhz).
    ~Adreno Idler ON
    ~Workload : (default 4) bisa set di (6) agar battery ga boros2 sekali. (silahkan set di (5) JIKA dirasa ada micro lags atau stutter saat HEAVY tasks/games)
    *yg lainnya biarkan default.
    ◀I/O scheduler▶
    ~ Internal Storage :
    Fiops - read-ahead 1024kb
    ~ External Storage :
    *set 1024 jika gunakan microSD 32Gb UHS-I
    *untuk 64 - 128Gb UHS-1 bisa set di 2048
    *jika gunakan microSD 32gb kebawah, set di 512kb (default untuk internal maupun external).
    ◀Virtual memory▶
    ~ Min free kbytes :
    default (3510) bisa set di 32768 (32mb) supaya system apps, foreground apps, tidak FC saat memory benar2 low/kritis.
    ◀Miscs control▶
    ~ Westwood / Cubic :
    Network TCP C.A (default Westwood) namun jika dirasa network WIFI, 3g/4g tidak stabil coba set di 'Cubic' (umum/linux).
    Westwood merupakan algorhytm paling terbaik saat ini untuk koneksi WIFI sangat stabil dan cepat (tethering dan router).
    ➡ just FYI ❗
    settingan CPU - GPU - I/O scheduler,Hotplug,, sangat berkaitan satu sama lain, saling mempengaruhi untuk overall results.
    secara kategori orientasi settingan bermacam2 ada yg lebih ke "pure battery life..pure performance...battery+performance...dll".
    Sharing saya diatas lebih ke orientasi balance "battery life + boost performance".
    Tidak ada yg namanya BEST Governor / BEST setting, semua berdasarkan selera dan hasil yg berbeda2 juga.
    ➡ Frequency Tables :
    Kesimpulan / Overall Results :
    jika dilihat dari tabel frekuensi diatas, maka bisa dikatakan settingan cukup selaras dengan hasilnya..
    ▶ Deep Sleep & 300Mhz :
    √ selama 2 jam 41 menit mengalami "deep sleep" ini sewaktu kondisi opx anda "standby/Idle" = kondisi dimana hp anda screen off, data selular ON, Sync ON.
    bisa dikatakan pemakaian battery sangat hampir minimal (almost near zero usage) mendekati nol.
    √ selama 2 jam 40 menit (hampir sama) berada di frekuensi 300Mhz atau minimum freq. mengapa demikian? hasil ini jg pengaruh dari settingan "CPU hotplug" dimana saya set 'Max Cores Screen Off = 2
    hal ini disebabkan karena dlm kondisi screen off, namun data selular ON, Sync ON.. maka CPU (1 core) hanya akan dan sesekali aktif (wake up) utk proses background sync (gmail ,WA, BBM, notifikasi,dsb) dan 1 core lainnya jika tidak dibutuhkan akan 'Deep Sleep'.
    Seperti yg saya katakan diatas di bagian pembahasan 'CPU hotplug'
    jika anda ingin set 'Max cores screen off' = 1 , maka dlm kondisi hp anda standby/Idle, jika tidak ada aktivitas yg mengharuskan CPU aktif (wake up) maka akan berada dlm kondisi 'deep sleep'. hal ini cukup berguna krn sangat irit battery (almost zero usage) hampir nol.
    × namun ada juga minus nya jika setting max cores screen off = 1 dan CPU dlm kondisi memasuki deep sleep, kemungkinan yg terjadi adalah : Sync tidak efektif atau tidak bekerja, Notifikasi telat, dan membuka aplikasi/melakukan aktivitas sekejap saat dari deep sleep bisa menjadi sangat lambat atau tidak responsif.
    ▶ Low - Medium - Max :
    ~ bisa dilihat dari tabel bahwa dari tweak CPU + Scheduler juga bekerja sangat selaras. bekerja dari low - medium - max frequency secara interaktif untuk di skala kan kembali ke freq yg lebih tinggi atau rendah.
    >>Max Freq 2265 Mhz :
    ~ dalam skala freq ini dibutuhkan untuk performance terbaik atau berada dalam aktivitas/tugas berat (heavy loads/tasks) : booting up, play games, multitasking, editing, dll..tapi tetap bisa irit battery dan tidak panas berlebihan (overheating) dengan cara trik 'Undervolting (UV)' yg telah saya sebutkan diatas.
    *untuk play heavy games seperti NFS (need for speed), RR3 (real racing 3) sangat lancar dan tidak mengalami lags/stutter. panas sangat minimal. battery index per 30 menit menguras 10% battery dengan skala 3:1 !
    (bayangin kl anda pakai stock kernel oos 2.2.1 tanpa bisa di tweak, per 30 menit play medium-heavy games menguras 30% battery, skala 1:1)
    ✔ Dengan hasil settingan yg sangat pas anda bisa mendapatkan battery life + performance yg cukup memuaskan. dengan max prioritas performance maka battery akan sangat boros, sebaliknya dgn max prioritas battery life maka performance akan kurang. dengan sedikit tweak tips dari saya maka yg bisa didapatkan adalah "Optimal balanced" ❗
    ➡ WAJIB dan harus dipahami bahwa secara keseluruhan daya tahan battery/performance/speed/smoothness, dll,dll juga dipengaruhi oleh banyak faktor.. seperti sinyal hp, screen brightness, koneksi internet, settingan hp, memory low, Background app Sync, suhu, dll dll, disamping behavior si empu nya alias cara pakai si user itu sendiri.
    ***INGAT: panduan diatas bukan lah mutlak namun hanya sedikit share pengalaman, anda bisa men-tweak sendiri sesuai selera dan keinginan masing2 dengan results yg berbeda-beda !
    Goodlucks.
    Regards,
    SapilautX
  2. Shinta H
    Community Manager Apr 22, 2016
    SapilautX likes this.
  3. Papao
    KitKat Apr 22, 2016
    Papao , Apr 22, 2016 :
    Pantasan, Bos mu gak naikin pangkat & gaji mu karena konsentrasi dan fokus pada hal2 yg lain ... :D:D:D
    Daripada jadi pegawai, mendingan kamu buka toko service hp saja ... hihihi ... :D:D:D
    Nogomong2 cicilan 0% udah diseutjui belum ... aku punya udah, tapi OPX onyx ku keburu ku jual ... :D:D:D
    Bagian yg utk beginners, ada yg tertarik, aku punya ide, workshop satu hari, hari minggu, sewa dimana yg murah tanpa ac buat ngajari hal2 simple seperti unlocking, flashing, ..., seklaian, buka OPX nya utk melihat isi2 nya ... PIC nya siapa yah??? ... :D:D:D
  4. moldayajib
    Gingerbread Apr 22, 2016
  5. Kimpol
  6. SapilautX
    Ice Cream Sandwich Apr 23, 2016
    SapilautX , Apr 23, 2016 :
    tet tot ! out of topic :p
    auk nih blm saya cek, tgl cetak tgl 25
  7. SapilautX
    utk pertama dan mudah undervolting aja dulu. mayan bisa ngirit battery
  8. SapilautX
    msh jauh dr expert bro. msh bljr. bljr bikin otak hp sm otak sendiri korslet, bahaha
  9. SapilautX
    Papao likes this.
  10. SapilautX
    Ice Cream Sandwich Apr 25, 2016
    SapilautX , Apr 25, 2016 :
    ADDITIONAL : Sony Xperia Keyboard is in the house ❗ ❗
    neng sis..mas broo ❗
    After Sony Music & Album now it's time for Xperia Keyboard for Loliipop! Ver. 7.1.A.0.28
    Whats New! ver. 7.2.A.0.32
    ▶▶4 new Skins added (Blue, Green, Pink, Purple)
    ⏩Super cepat..ringan..akurat + dictionary (optional language dict. download)
    ⏩ Dark, Light, Classic skins
    ⏩ language dictionary downloadable
    ⏩ Emoji, Smiley, Icon dll
    ⏩ Numeric Keyboard
    ⏩ One handed Keyboard layout (kiri/kanan)
    ⏩ Personal dict, Word suggestion, Gesture typing, dll..dll..
    ◀Direct link▶
    ➡ Syarat dan Cara Flash + Update latest Ver. :
    * rooted
    * twrp recovery
    ▶ download .zip (jgn di extract)
    ▶ taruh di internal storage/sd card root directory (diluar folder)
    ▶boot ke TWRP recovery
    ▶klik Install trus pilih. Zip file nya
    ▶selesai! Reboot.
    *Utk Update ke Latest Ver. silahkan update manual di Google Playstore.
    ➡ Cara gunakan Xperia Keyboard sebagai default keyboard :
    ke Settings > Language & Input >
    Current Keyboard > pilih/enable 'Xperia Keyboard'.
    *Screenshots "new skins" dibawah.
    ENJOY ❗
  11. SapilautX
  12. SapilautX
    Ice Cream Sandwich May 5, 2016
  13. SapilautX
  14. SapilautX
    Ice Cream Sandwich May 13, 2016
    SapilautX , May 13, 2016 :
    OK neng sis.. mas broo.. Music Lovers, it's time for MOD ❗❗ no more weak effect, no more loussy sound ❗
    ◀™Viper4Android FX 2.4.0.1 "Dark Material"▶
    Apa itu Viper4Android FX ? silahkan googling sendiri !
    Agak agak ribet nih tapi yee, but definitely worth to try ❗
    *hati2 pecah gendang telinga pake V4A ❗ ha ha
    Achtung ❗
    ◀ before do anything, keep in mind that do this with your own risk ❗▶
    Bahan-Bahan :
    SELinux Mode Changer
    Viper4Android FX 2.4.0.1 ZIP
    Viper4Android FX 2.4.0.1 APK
    Busybox : cari di playstore ye neng/bro (dev: stericson)
    Pra-syarat :
    > Earphone/Headphone yg ori dan mantab agar terasa effect Bass/Treble nya.
    > Busybox latest ver. (official playstore)
    > TWRP (blm coba kl pakai CM recovery bisa apa ngga, harusnya sih sama aja bisa)
    > SELinux = Permissive !
    Install Instructions, dari XDA :
    APK Method
    1. Place APK on your Internal or External SD Card.
    2. Install the APK with any File Manager.
    3. Start V4A and install the driver of your choice.
    4. Disable LPA if prompted.
    5. Reboot Device.
    ➡ cara non aktifin audio fx/effect bawaan.
    Android 6.x Marshmallow dari XDA.
    Nexus/AOSP Devices Fix : (CM based on AOSP jg jd sama)
    1. With a File Manager (root exp./es file mgr.) locate " /system/vendor/etc/audio_effect.conf" and rename "audio_effect.conf" to "audio_effect.bak" (Renaming this file will make it inactive but while keeping it backed up just in case this doesn't work for you, however it appears this file is not needed as no negative effects occur, and this should fix V4A.)
    2.Reboot Device.
    Untuk 5.1.1 (ZIP method) bisa langsung pakai cara ini :
    ➡ ➡ ini tuto (tutorial) cara saya : ZIP Method (bnyk yg lebih berhasil dgn cara flash zip dibanding APK) tapi terserah, selera aja mau pakai cara yg mana (yg dirasa lebih mudah dimengerti).
    > Tested ROMs by me : 5.1.1 / 6.0.1
    >> download busybox, lalu buka dan harus ter install di( system/xbin) dan jg di (system/bin).
    >> download selinux mode changer (klik permissive , dan check notif after reboot bla bla dibawahnya, spya tau selinux mode langsung berubah setelah reboot nanti)
    >> buka setting hp..setting - dev. options - scroll kebawah dibagian media trus klik/enable " use AwesomePlayer" instead of NUplayer bla bla (atau apapun yg ada di opsi dev.option kamu selain NUplayer) *saya kasih SS dibawah
    >> download Viper4A .zip dan flash .zip via recovery TWRP.
    >> buka app Viper4A nya, grant root permission kl diminta, trus klik install driver.
    >> reboot hp
    ▶▶setelah reboot, buka viper4A kl masih error install driver, pastikan busybox terinstall dgn benar, Akses Root, dan SELinux hrs sdh Permissive◀◀
    ** Optional Method:
    jika msh ada masalah install driver Viper4A, baca urutan dan detail dgn benar dari tuto diatas. atau coba cara dibawah
    berlaku utk masalah driver atau effect nya tidak bisa / tidak berpengaruh di play dari music player. di app viper4A klik menu di atas pojok kanan, lalu klik "compatible mode" pilih "compatible" (kl di normal mode ga bisa install driver / effect nya).
    *Kl driver/effect bisa di 'normal mode' ya ga usah diganti) *liat SS dibawah
    Achtung ❗❗❗ jgn lupa backup buat jaga2 (do with your own risk, don't blame me if something goes wrong because you messed up). just googling if you think it's more easier for you to understand the installation.
    Compatible Music Players :
    PowerAMP, Google Music, dll.
    Saya pribadi pakai Sony Music latest ver. di playstore.
    Last words.. for me, this app Viper4Android™ FX is Fckin Awesome ❗
    Goodlucks and Enjoy!
    Screenshot_2016-05-13-18-25-04.png Screenshot_2016-05-13-18-26-14.png Screenshot_2016-05-13-18-26-01.png
    1463330455432.jpg Screenshot_2016-05-15-23-34-42.png Screenshot_2016-05-16-14-11-44.png
  15. SapilautX
    Ice Cream Sandwich May 17, 2016
    SapilautX , May 17, 2016 :
    ✴ NEW! Google Keyboard 5.0.25 (arm) ✴
    What's New ❗
    • Slide finger across space bar to move cursor ««« ini fitur keren bgt dan berguna
    • Slide left from delete key to gesture delete words ««« ini fitur keren bgt dan berguna
    • Long press suggestions to remove learned or dictionary words
    • Settings to add key borders or symbol hints ««« sangat berguna meminimalis typo
    • One handed mode for large screens (kiri/kanan)
    ✖ minus dlm hal "word suggestion"
    bahasa indonesia kurang presisi dan data base dictionary kurang lengkap. untuk masalah ini "Xperia Keyboard" tetap lebih juara.
    ▶ Direct link ◀
  16. SapilautX
    New tweaks ~New Records ❗ 6 Hours 28 mins
    *no need doze, no xposed, no greenify, etc..
  17. SapilautX
    Ice Cream Sandwich May 18, 2016
    SapilautX , May 18, 2016 :
    Tips n Tipsy ❗ :p
    ◀Undervolting & Battery Calibration▶
    Kalibrasi Battery :
    1) charge hp sampai battery full 100% lalu gunakan seperti biasa.
    2) sampai battery tinggal 1% colok ke charger dan matiin hp total.
    3) tunggu sampai led warna hijau (battery full 100%) lalu cabut dan nyalakan hp. gunakan normal seperti biasa
    4) sampai battery low batt (5%) colok charger (hp jgn dimatiin) isi sampai 50% lalu cabut dan gunakan normal seperti biasa.
    5) pakai sampai 1% (jika battery anda bisa sampai 1% sangat bagus) selanjutnya colok charger (jgn matiin hp) lalu charge sampai full 100%.
    *5a) jika battery anda tiba2 dari 10% atau 7% tiba2 drop langsung ke 1% atau bahkan tiba2 mati, berarti battery belum ter kalibrasi dengan tepat. maka matiin hp dan charge sampai 50% (kira2 aja +/- 50 menit ~ 1 jam) nyalakan hp lalu gunakan seperti biasa sampai battery berhasil menyentuh 1% tanpa drop. jika berhasil maka langkah selanjutnya..
    6) jika berhasil sampai 1% berarti battery sudah ter kalibrasi dengan tepat (jika tidak, ulangi no.*5a) lalu charge hp dlm keadaan nyala sampai full 100%.
    7) selanjutnya selalu charge battery jika mencapai <60 >50 % sampai 90%
    8) lakukan rutin charge min. 50% s/d max. 90% maka battery anda akan awet muda dan tahan lama (Jika yg Maha Kuasa Mengizinkan) LOL.
    9) silahkan di test kl penasaran, pakai battery dari 90% sampai 1% dan cek SOT jika berhasil lebih dari 6 jam, maka WOW anda berhasil ! jika tidak jgn marah yee ! namanya juga "Tips n Tipsy" !
    **already tested by me using 4G/Lte ON (no wifi at all) bbm, WA, Gmail, Line, Gapps ON. with SOT 6 hours 28 mins (still 18% left)
    IMPORTANT: dlm kondisi hp di charge jgn sambil dipakai apapun agar proses kalibrasi lebih optimal
    *Undervolting below...
  18. SapilautX
    ◀UNDERVOLTING OPX▶
    Sorry ye males ngetik nya lagi ke bhs sehari-hari he he. use Google Translate if you want :p
    copy-paste from my own post :
    just in case you need as comparable :
    *if you're still on stock ROM. I assume u've already rooted and installed custom kernel like (blu_spark/boeffla).
    >> download and install, i recommend for easy use it's "kernel adiutor" app in playstore. (you'll needed this app to UV your opx)
    >> open kernel adiutor app and go to "cpu voltage" menu section.
    >> from there you can UV your device. as you can see there default voltage value of your current device.
    >> you may go manual or set global offset to UV. i suggest use global offset to avoid wrong input or misscalculation value.
    >> you can press (-) to UV either (+) to OV. just fyi opx soc has pvs bin 'pvs12' which means its allowed you to UV down to -100mv even a bit lower than that.
    >> you may try and start from -50 to -75 for global offset. if its OK and stable enough then you may try lower -75 to -100. and see if it's stable enough on your device (no reboots, no hangs, etc)
    >> make sure you un-enabled the "apply on boots" toggle at up right corner while performing UV (to avoid unexpected behaviour if something goes wrong). then you may enable the toggle if you think its setted and you're going ahead. and reboot device to apply the changes.
    **NEW updates: Undervolted -110. lower than that i get reboots.
    it has been stable for almost 2 months of usage. SOT could up to 7 hours ❗ WOW isn't it ! and no more overheating in heavy tasks. *depends on your personal usage and overall setting tho'.
    so, mine -110mv (using global offset) :
    at lower freq 300 mhz >< 715 mv
    at max freq 2265 mhz >< 940 mv
    currently i am using latest blu_spark kernel r137.
    hope it helps.
    *SS dibawah
  19. Papao
    KitKat May 18, 2016
    Papao , May 18, 2016 :
    Opx ceramic ku sayang di obok2, nunggu lah mm resmi, gak mau di custom, salah2 jadi ceramic benaran hihihi...:D:D:D
    Nih, @Hermanto.liu kemana yah...kena php langsung gak nogol2... Aduh....kemari dong....:D:D:D
  20. SapilautX
    he he noticed it. *your vote :D
    Papao likes this.
