Orzly does not cover the entire opo screen glass surface
  1. yaltis
    Jelly Bean Aug 16, 2014
    yaltis , Aug 16, 2014 :
    I just received and applied Orzly tempered glass screen protector today.It was Very easy in did.No bubbles no dust .
    Perfect round edges.It covers front camera and sensors witch i like.
    Up to now no big issues in viewing angles.Very clear view.
    But a big question:WHY DOES NOT COVER THE SCREEN FROM EDGE TO EDGE?
    it leaves 1mm to 2 mm from each side of my screen .the same and more from top and bottom.
    Are all tempered protectors do the same?
  2. carl_gadget
    Gingerbread Aug 16, 2014
    jokicha, yaltis and UnknownSoul like this.
  3. UnknownSoul
    UnknownSoul , Aug 16, 2014 :
    This right here. If you had a tpu case you'd see why they cut it to be case friendly.
    yaltis likes this.
  4. drmartin
    Lollipop Moderator Aug 16, 2014
    drmartin , Aug 16, 2014 :
    Ultimate Shield (also tempered glass) gets it all!
  5. yaltis
    if you own an opo you can see that there is a plastic metallic border around the screen .so this would not be an issue
  6. drmartin
    still, unless they changed the design, the screen is the outermost component, meaning it will be the thing to be scratched when you put it down on your table at lunch.
  7. UnknownSoul
    It is with TPU cases. They cover that extra space on the screen.
    yaltis likes this.
  8. yaltis
    did you apply one or just from the specs?
  9. drmartin
    I applied 2. One on mine, one of my girls.
  10. yaltis
    Any issue with the case,as others have mentioned already?
  11. drmartin
    Which issues (think i missed that)... I have used the official 1+ back covers as well as the fake shizzle from ebay. All plays nice. And Ultimate Shield only costs £10.
    yaltis likes this.
  12. Jbleakley93
    Jbleakley93 , Aug 16, 2014 :
    I've just ordered an orzly one for mine, on my N4 I had a screen protector that left a 2mm gap from the edge of the phone and never had a problem with it.
    I've also gone for an orzly gel case for now to protect the rest until a nicer one comes on the market
    yaltis likes this.
  13. yaltis
    Some friends are saying that if you use a tpu case and the tempered glass, covers the entire surface ,then the orzly could be lifted off by the case
  14. drmartin
    Most certainly not having any issue with the case and ultimate shield. That in mind, I took the back cover off now since they have exchangable back plates now... just waiting for kevlar to be released so my phone is bullet proof. :)
    yaltis likes this.
  15. carl_gadget
    carl_gadget , Aug 16, 2014 :
    As you flip the case over it is still under quite a tension and if it encountered an edge right then it would risk being lifted. Plus the edge is a weakness, if it gets hit on the edge then it can crack. The case does the edge and the cover due the rest.
    yaltis likes this.
  16. jokicha
    Jelly Bean Oct 9, 2014
    jokicha , Oct 9, 2014 :
    i ordered an orzly glass screen protector as well, should be here next week. i was worried about this issue of the screen covering the screen to the brim which could cause problems when i put my case over it.
    what you described is a good thing. itll prevent the screen protector from being lifted from the screen when putting on/taking off the case
