3
Orzly scren protector fitment issue
  1. RNair1
    Froyo Nov 30, 2014
    RNair1 , Nov 30, 2014 :
    Requesting comments and thoughts from those who have used the Orzly tempered glass protector. I got the protector in mail this weekend from Amazon. I expected it will fit the whole raised screen but it does not. It seems shorter than screen by 2 mm and narrower than screen by 1 mm on each side. If you have experience with this product can you comment if this is the standard fitment on the screen? I do not want to apply on the phone if this is wrong size. Photos below.
    Back of package has the bar code on a sticker, does not seem part of original package. Amazon price check app itself does not read this bar code. Was this the bar code for those who had good fitment?
    Front of package. Again the For One Plus is a sticker.
    alchang, Joyyy and JTace like this.
  2. KiiLLER ViRUS
    Eclair Nov 30, 2014
    arrisquddus and JTace like this.
  3. Naokia980
    Ice Cream Sandwich Nov 30, 2014
    Naokia980 , Nov 30, 2014 :
    You get what you pay for..So deal is deal..
    JTace likes this.
  4. gurpeer
    Gingerbread Nov 30, 2014
  5. RNair1
    Froyo Nov 30, 2014
    The unprotected 2 mm of screen is enough to worry.
    Venny and Tricia24 like this.
  6. RNair1
    Froyo Nov 30, 2014
    I am trying to get helpful information. Your comment does not make sense as this product has decent reviews on this forum. Also I have paid a decent price for this product in my opinion. All screen protectors I used in the past covered full screen and did not leave gaps like this.
    My objective is to get feedback from those who have Used the product already, for the benefit of those who plan to buy it in future.
    Garywehrle and Tricia24 like this.
  7. BobRSanchez2
    Honeycomb Nov 30, 2014
    BobRSanchez2 , Nov 30, 2014 :
    Did you use a ruler to measure 2mm? Because 2mm is actually a very large gap. From the picture, it looks more like 0.5mm at most, and I'm fairly sure that's because they wanted it to be case-friendly.
    rvu5 likes this.
  8. justinb928
    justinb928 , Nov 30, 2014 :
    All the tempered glass protectors that Ive bought for every phone that Ive owned have had a small gap around the edges. Its fine.
    ExpatZ and Garywehrle like this.
  9. yuviyuval
    Froyo Nov 30, 2014
    yuviyuval , Nov 30, 2014 :
    I bought two of these screen protectors from two different sellers (one of them being Amazon). Both of them are exactly like that.
    They are designed this way to avoid sharp edges and so cases can fit without them lifting the screen protector.
    The orzly glass screen protector is one of the best out there for the OPO, don't worry.
    what u think, ExpatZ and Garywehrle like this.
  10. pevaxes
    Eclair Nov 30, 2014
    pevaxes , Nov 30, 2014 :
    I had a similar problem. I applied mine yesterday, and since it was my first time applying a screen protector, I also had a big bubble at the bottom, despite following all of the necessary precautionss. Luckily, the bubble is just on the bezel, so I won't remove the screen protector.
  11. Joe90
    Joe90 , Nov 30, 2014 :
    There is a thread about the Orzly premium tempered glass screen protector and the barcodes quoted end in 882 and 891!
    The one ending 891 is a correct fit, whilst the other one is not.
    My Orzly screen protector has this barcode, nothing like yours:
    5 055313 930891.
    Perhaps this is under the barcode sticker, although mine also has the barcode on a sticker, but the sticker is smaller and does not obliterate the graphics alongside the "included"
    sarin.j and RNair1 like this.
  12. toastytoast1234
    Marshmallow Nov 30, 2014
    toastytoast1234 , Nov 30, 2014 :
    Yup, I have an Orzly and it fits perfectly. No idea what the specific part number was, threw the packaging away months ago.
  13. soriFern
    soriFern , Nov 30, 2014 :
    Screen protectors can be tricky. Unless you get a robot to put it on you may not get a good fit. Lol. Yours looks alright though
  14. netr0pa
    Jelly Bean Nov 30, 2014
    netr0pa , Nov 30, 2014 :
    You are too picky my friend....
    I have bought 2 different shields and they both have some gap and its ment for the phone cases. Just activate that brain for a while and you will see that it makes sense.
    yuviyuval likes this.
  15. Lancelot_69
    Lollipop Nov 30, 2014
    Lancelot_69 , Nov 30, 2014 :
    I bought it, did not like it but had already opened it. I threw it in the garbage. If you have not opened it, return it! You are correct about not fitting!
  16. yuviyuval
    Froyo Nov 30, 2014
    The guy has just posted a pic of the protector on his phone, so how can he not open it?
    Garywehrle likes this.
  17. Serbian Overlord
    KitKat Nov 30, 2014
  18. Majed
    Froyo Nov 30, 2014
    Majed , Nov 30, 2014 :
    Mine the same as yours... I guess you have the one which has the barcode of 891 which is a perfect fit.
    I aligned it very well as you did. This fit is normal man... Never mind
  19. Lancelot_69
    I did not click on photo. I assumed it was a picture of package. So he lives with it or tosses.
  20. Antoine Vdb
    KitKat Nov 30, 2014
