OS 12.1 bad battery :(
  1. Ahmed Eldeknawy
    Eclair Aug 27, 2015
    Ahmed Eldeknawy , Aug 27, 2015 :
    hi all
    after update to os 12.1 ifeel the battery bad more thane os 12 :( :( any one help me to fix this problem ?
  2. hlin9
    Honeycomb Aug 27, 2015
  3. championspike
    Ice Cream Sandwich Aug 27, 2015
  4. A.S
    rimkidikan and Ahmed Eldeknawy like this.
  5. Ahmed Eldeknawy
    Eclair Aug 27, 2015
  6. Soundarya
    Soundarya , Aug 27, 2015 :
    see the pinned thread.it works fine for them
  7. Ahmed Eldeknawy
    Eclair Aug 27, 2015
    7abeby ya ebn balady khosh fe la7m akhok :)
    ana mnazl el soft kamel we 3amlo 3la os 12 ba3d ma 3mlt format cash we system we data bas moshkelt el battery de mdy2any 2wy
  8. Bartnl
    Lollipop Aug 27, 2015
    Bartnl , Aug 27, 2015 :
    Great battery live here with 12.1. Even better then with 12.0.
    Do a clean install and you'll be fine
  9. championspike
    championspike , Aug 27, 2015 :
    english....
  10. Kaizoku
    Kaizoku , Aug 27, 2015 :
    let it drain and charge a few times and then check if there are improvements.
  11. Ahmed Eldeknawy
    Eclair Aug 27, 2015
    ammm .. i need some one help me to get it step by step because i do instal it on os 12 after do format cash and system and data
  12. Ahmed Eldeknawy
    Eclair Aug 27, 2015
    i do it for one time and no change :(
  13. Kaizoku
    One time won't do it. Try a few times. Also you can recallibrate your battery by letting it drain to zero and then charge it for six hours without activating your device. Last but not least, you could turn off permissons of applications with the privacy guard to spare battery juice.
    Hope this helps.
  14. Ahmed Eldeknawy
    Eclair Aug 27, 2015
    thanks my friend so much .. i do clean install again and do your steps and see
  15. Drlipton
  16. rimkidikan
    Cupcake Aug 30, 2015
