otg connection problem with my oneplus 5t
  1. piyush931994
    Cupcake Oct 22, 2019
  2. Mr_Cyrox
    KitKat Oct 22, 2019
    Mr_Cyrox , Oct 22, 2019 :
    Could be many things
    • OTG not turned on
    • The cable(s) are broken
    • The connection is bad (dust/dirt)
    • The device you're trying to connect is not compatible
    Information helps
  3. piyush931994
    piyush931994 , Oct 22, 2019 :
    i have tried many otg cable and all function are on
  4. Mr_Cyrox
    KitKat Oct 22, 2019
    Ok now check the rest 3 that I listed in my last post
    pablofg1978 likes this.
  5. piyush931994
    i have chacked all points but otg not working..i want connect pen drive but i could not connect
  6. Mr_Cyrox
    KitKat Oct 22, 2019
    Can YOU list what you tried so far?
  7. piyush931994
  8. Mr_Cyrox
    KitKat Oct 22, 2019
    No, if you want to talk in hindi go to an Indian part of the forum
    (select Indian language or whatever country speaks hindi)
  9. piyush931994
    otg function is on..cable is not broken..device is suitable for connect..this otg cable is working with other oneplus 5t device so otg cable is not broken
  10. Mr_Cyrox
    KitKat Oct 22, 2019
    What about the port itself in the phone?
    Is it working properly?
    I. E. does it dash charge while the cable is being flexed near the port?
    Or can you easily connect the phone to a PC and have a stable connection?
  11. piyush931994
    i can connect easily my phone with pc
  12. Mr_Cyrox
    KitKat Oct 22, 2019
    And what about the other one?
    Reply fully
    W1525436949859 likes this.
  13. piyush931994
    sometime dash charge do not work in my phone
  14. Mr_Cyrox
    KitKat Oct 22, 2019
    There you go
    Your port is damaged/dirty
    Try get it cleaned or get it replaced
  15. piyush931994
    ok sir..how can i clean my port?
  16. Mr_Cyrox
    KitKat Oct 22, 2019
    Take a toothpick or something similar and try to clean it by getting the dust/lint/dirt out
    Take your time with it
    If it doesn't help (if you still can't fash charge consistently) then contact the service center to get it replaced
    The port seems to be the issue with OTG
    Btw does anything else connect via OTG or is it only that pen drive?
  17. piyush931994
    i was trying to connect pendrive with otg cable
  18. Mr_Cyrox
    KitKat Oct 22, 2019
    What about anything else?
  19. piyush931994
  20. Mr_Cyrox
    KitKat Oct 22, 2019
    You can try other stuff and see if they work properly
    If they don't then the port is 100% at fault here
