4
OTG not working in OnePlus 5.. i have already enabled OTG
  1. allanj13
    Gingerbread Jul 4, 2017
    #41
    sreejith krishnan and lostLambda like this.
  2. jmsrajkumar
    jmsrajkumar , Jul 4, 2017 :
    lol ...when I'm posting got a notification of urs.
    #42
    sreejith krishnan likes this.
  3. lostLambda
    Lollipop Jul 4, 2017
    #43
  4. allanj13
    allanj13 , Jul 4, 2017 :
    Haha.
    I got a screenshot of what I just typed in the field after I posted. And I was like "wtf"
    #44
  5. G_Vishal_Jituri_uBfn
    Eclair Jul 4, 2017
    #45
    lostLambda and sreejith krishnan like this.
  6. jmsrajkumar
    bravo,bravo bro [e]1f44f[/e][e]1f44f[/e][e]1f44f[/e]
    #46
    hashmi5 and sreejith krishnan like this.
  7. sreejith krishnan
    Froyo Jul 4, 2017
    #47
  8. sreejith krishnan
    Froyo Jul 4, 2017
    sreejith krishnan , Jul 4, 2017 :
    Not working. After enabling also.
    #48
    lostLambda likes this.
  9. G_Vishal_Jituri_uBfn
    Eclair Jul 4, 2017
    #49
  10. sreejith krishnan
    Froyo Jul 4, 2017
    Mine not working.
    #50
  11. allanj13
    You should try different otg cables because most of the cheaper ones don't work with op. Also you can use a type c to micro usb converter and plug in an existing micro usb port otg and try it out.
    Most of the cheaply available type-c otg cables have certain problems with some devices
    #51
  12. sreejith krishnan
    Froyo Jul 4, 2017
    The otg am using is working with my op2. Not working with my op5.
    #52
  13. allanj13
    Could you try it with some one's op 3t or op5?
    it should clear if it's a hardware issue. And I myself hasn't checked my otg. Now I'm worried [e]1f613[/e]
    #53
  14. sreejith krishnan
    Froyo Jul 4, 2017
    I checked with op2 not having any other phones to check.
    #54
  15. jmsrajkumar
    possible methods you can try:
    1. use the same otg with another op5 (find a person who has one [e]1f609[/e])
    2. Try installing a 3rd party file manager which shows the otg folders in that app.(seems lousy)
    #55
  16. sreejith krishnan
    Froyo Jul 4, 2017
    I will try with another phone, but i also tried connecting mouse which would work without any software and all. But turns out that is also not working.
    #56
  17. lostLambda
    #57
  18. sreejith krishnan
    Froyo Jul 4, 2017
    No. Am not having twrp installed
    #58
  19. erickok755
    erickok755 , Jul 4, 2017 :
    both of my USB flash drive work OK. I use the type c converter. read write is perfect.
    #59
  20. Dhruv Gaur
    Donut Jul 4, 2017
    Dhruv Gaur , Jul 4, 2017 :
    Mine working after i removed my otg and disabled the otg storage button, and then re enabled it 1 or 2 times. The issue was gone after that
    #60
