OTG PROBLEM SOLUTION ON ONEPLUS 2
  1. MOSHE TVITO
    Eclair Jun 25, 2016
    MOSHE TVITO , Jun 25, 2016 :
    Well I also had a problem with OTG connection
    And I had to buy a ONEPLUS ADAPTER
    So finally I can see my files at the phone and at the USB , but again the main problem is that i can not transfer files between them
    Okay there is the solution
    I downloaded the app USB OTG FILE MANAGER FOR NEXUS
    Cost of 8.59 PLN
    now I can see the files on the phone and USB
    And can move files between theme with Copy and Paste
    its important to put the phone on OTG mode before running application
    to do so
    You enter to settings
    USB Storage +
    Then open up the possibility Turn OTG with the three poit aboth
    Hope I helped
    Bye everyone
  2. hulabalua
    Ice Cream Sandwich Jun 25, 2016
    pa5t1s likes this.
  3. pa5t1s
    User of the Year 2014 Jun 25, 2016
  4. Joel Hallklint
    Cupcake Jun 30, 2016
  5. Philippe V
    Cupcake Jul 2, 2016
    Philippe V , Jul 2, 2016 :
    Fabulous ! It worked as you described it! Thanks Moshe, you solved my problem..
  6. MOSHE TVITO
    Eclair Jul 2, 2016
    MOSHE TVITO , Jul 2, 2016 :
    I am happy i helped you
    Cause i was with that problem since i had the oneplus two
    I thoth that the oxygen 3.0.2 will fixit but nothink
    I am glad for hrlp every one eith this problem
  7. marinobiagio
    KitKat Jul 2, 2016
  8. octane007
    Cupcake Dec 10, 2016
    octane007 , Dec 10, 2016 :
    I purchased the one plus otg usb type c adapter anf formatted my pen drive to the required format (FAT32). I've also connected a micro usb type otg via the adapter.
    The micro usb otg is perfectly functional (i've tried using it with a different device).
    Also, my otg is also enabled from storage settings.
    But, i'm still not able to access my pen drive.
    What's the solution?
    I've added a picture of the type of connections that i'm using.
  9. octane007
  10. tanmaysalunke
    Gingerbread Dec 10, 2016
    tanmaysalunke , Dec 10, 2016 :
    Straight away Buy Xiaomi's USB Type C Adapter .
    It does Both Charging and Data Transfer
    I Bought for 100/-
  11. G_Kartik_Popli_KmQH
    Cupcake Feb 9, 2017
    G_Kartik_Popli_KmQH , Feb 9, 2017 :
    From where did you purchased it ?
  12. devdutta
    Cupcake Feb 9, 2017
  13. CemX
    Cupcake Feb 10, 2017
