OTG stopped working suddenly.
  1. Sandy K
    Froyo Feb 14, 2017
    Sandy K , Feb 14, 2017 :
    I connected pen drive to my OP3. it was working smoothly. I then connected hard disk. It was also working. I disconnected & connected hard disk again but its not getting recognized now. Do I need to reformat OS? Any other suggestion is much appreciated. Thanks in advance.
  2. Kiran.a.joseph
    Jelly Bean Feb 14, 2017
    Sandy K likes this.
  3. Sandy K
    Froyo Feb 14, 2017
    Yes. Restarted mobile, Wiped cache. But no luck. Will try with another OTG connector.
  4. G_Simon_Carl_N._De_Leon_
    Honeycomb Feb 15, 2017
    G_Simon_Carl_N._De_Leon_ , Feb 15, 2017 :
    Are you sure you have OTG enabled? In case you are, you could try to dig in the developer settings and find an option there that says something like charging and change that to file transfer. Hope it helps! Cheers!
    Sandy K likes this.
  5. sivakumarun
    Eclair Feb 15, 2017
    Sandy K likes this.
  6. Sandy K
    Froyo Feb 20, 2017
    Sandy K , Feb 20, 2017 :
    Done factory reset but it's not getting detected. OTG device working on other mobile. Any help is much appreciated.
  7. Sandy K
    Froyo Feb 20, 2017
    Yes oTG is enabled. Followed steps mentioned by you but no luck :(
  8. Sandy K
    Froyo Feb 20, 2017
    Thanks. But same connector is working on nother phone. I think it's some software problem but unable to get any solution.
  9. lretana78
    Eclair Feb 20, 2017
    lretana78 , Feb 20, 2017 :
    Having same problem here, got a usb card reader, It worked the first time and next time I tried to use it did not work. Tried restarting phone, re-formatting cards, and none is working. Also the reader can be read in other devices
  10. Rajtapu
    Cupcake Feb 20, 2017
    Rajtapu , Feb 20, 2017 :
    I think Reset may work in this case.
  11. petarda01
    Froyo Feb 20, 2017
    petarda01 , Feb 20, 2017 :
    Try plugging the adapter both sides up, I noticed that my OTG adapter works perfectly when plugged one way up and not at all when the other.
  12. lretana78
    Eclair Feb 20, 2017
  13. lretana78
    Eclair Feb 20, 2017
    Already tried :(
  14. G_Sachin_Jain_hjVR
    Cupcake May 17, 2017
    G_Sachin_Jain_hjVR , May 17, 2017 :
    Today my One Plus 3T also suddenly stopped taking OTG, I was using finger sensor device Morpho, then I charged it by its charger, then I connected again OTG but it didnt worked.
  15. G_Sachin_Jain_hjVR
    In between working, OTG stopped working. I tried these steps:
    1. Restarted Mobile
    2. Rollover OTG upside down and vice versa.
    3. Checked OTG in other OP3T, wokring fine.
    4. Checked OTG connected with Pendrive, Mouse, Morpho Finger Sensor. Not working
    5. Tried Adapter also but not working.
  16. ghostofcain
    Marshmallow May 17, 2017
    ghostofcain , May 17, 2017 :
    Have you tried cleaning usb socket?
  17. G_Sachin_Jain_hjVR
  18. razuniga
    Cupcake Oct 25, 2018
    razuniga , Oct 25, 2018 :
    Did you ever solve this? I've had this problem for months and never found a solution, could you connect it to a PC? My USB C doesn't recognize OTG and does nothing when connected to a PC through USB, tried the original cable and a 2nd new OP dash cable. It charges perfectly but it will not transfer data. Replaced the USB C port flex with a new one, and have updated the software multiple times
