OTG
  1. billq
    Jelly Bean Oct 13, 2015
    billq , Oct 13, 2015 :
    You need the op2 official adaptor it won't show in storage .it shows in files ,
    pa5t1s and keithnyc like this.
  2. killing.devil
    Honeycomb Oct 13, 2015
    killing.devil , Oct 13, 2015 :
    Use the OnePlus micro usb to type c converter with any standard otg cable
    It works....
    pa5t1s, keithnyc and billq like this.
  3. Frecce D'Oro
    Froyo Oct 13, 2015
    Frecce D'Oro , Oct 13, 2015 :
    There still is no safe way to unmount a USB drive mind. Maybe this can be added to the next update for oxygen?
    Sooner or later you will probably end up with a corrupt drive if you just disconnect the OTG Adapter!
    MarkLFS likes this.
  4. keithnyc
    Moderator Moderator Oct 13, 2015
    keithnyc , Oct 13, 2015 :
    It does work, but not with many of the knock off third party usb to c converters (e.g., it will allow you to charge your device, but may not transfer or read data) ....you need to buy the official OP2 converter for assurance that it supports USB OTG.
    pa5t1s, surfrndk and billq like this.
  5. Deactivated User
    Oct 14, 2015
  6. Evidz-7
    Eclair Oct 14, 2015
    Evidz-7 , Oct 14, 2015 :
    Evrything works it's juste the ps3 controller who doesn't work ... Help XD
    surfrndk likes this.
  7. osich
    Ice Cream Sandwich Oct 14, 2015
    pa5t1s and billq like this.
  8. Evidz-7
    Eclair Oct 14, 2015
    pa5t1s likes this.
  9. andretan
    Cupcake Oct 24, 2015
  10. Frecce D'Oro
    Froyo Oct 29, 2015
    Frecce D'Oro , Oct 29, 2015 :
    Why don't you just get a oneplus OTG cable -it's cheap enough?
    Manufactures can choose to implement any standard to their products as they see fit.
    I remember when Nokia Bluetooth headsets would only work with their phones as an example!
    pa5t1s likes this.
  11. andretan
    Cupcake Nov 3, 2015
    andretan , Nov 3, 2015 :
    OnePlus doesn't make a USB Type-C to OTG adapter...
    If you are referring to the OnePlus USB Type-C Adapter? (https://oneplus.net/oneplus-usb-type-c-adapter)
    In fact I tried to order it locally through the official OnePlus dealer in my country but it has been out of stock like forever...
    ButterFlYnez likes this.
  12. anshumangoyal
    Froyo Nov 3, 2015
    anshumangoyal , Nov 3, 2015 :
    How to see these Links. I am unable to open them as well. Are these available in India as well?
  13. Waleed hassan
    Donut Nov 3, 2015
    Waleed hassan , Nov 3, 2015 :
    Hi guys
    Your USB device must be in ntfs format other file systems like expat will not be detected mine was not detected I reformat it as ntfs now working perfet
  14. Frecce D'Oro
    Froyo Nov 6, 2015
    Frecce D'Oro , Nov 6, 2015 :
    My apologies - yes I should have said the oneplus micro usb to Usb-A adapter with the USB Type c adapter together!
    Can you order from another location on OnePlus website and have it shipped to you?. The adapter is not region specific!
    I have fun with mine configuring cisco routers with this setup and an usb to Serial adapter attached to the Oneplus OTG. Try doing that with a Iphone! ;)
    edit: which region are you in andretan?
    pa5t1s likes this.
  15. andretan
    Cupcake Nov 11, 2015
    andretan , Nov 11, 2015 :
    I've finally managed to order the OnePlus one... but Oxygen OS still doesn't allow us to unmount USB storage...
  16. jomaliakal
    Gingerbread Nov 13, 2015
    jomaliakal , Nov 13, 2015 :
    Here is a lot of confusion regarding OTG for OP2. I searched a lot for OTG in Amazon too. Found nothing solid. Its not in the OP2 store too. Some administrator held needed to remove this confusion. Means, need the clear settings for OTG support. Its there, but its not there. This is the current scenario.
  17. billq
    Jelly Bean Nov 13, 2015
    billq , Nov 13, 2015 :
    Mines OK on fat
  18. billq
    Even tho there are endless search items for this .you need the official adaptor from op to get drives to show .and it will show up in files
    #38
    pa5t1s likes this.
  19. billq
    All cables work for charging .you require the op official adaptor for drives
    #39
    pa5t1s likes this.
  20. pa5t1s
    User of the Year 2014 Nov 13, 2015
    pa5t1s , Nov 13, 2015 :
    False.
    Use OnePlus USB-C adapter and enjoy OTG.
    Search the forum for relevant threads : already discussed.
    #40
    pgidia and billq like this.
