Overheating and lagging via OnePlus 7
  1. MANAV1113
    Cupcake May 17, 2021
    MANAV1113 , via OnePlus 7 , May 17, 2021 :
    My device started to overheat to around 42-43°C while I am playing CODM battle royale and the game lagging is significant as well. This started to happen since I installed android 11. There were none of these issues before. Many other users are experiencing the same issue. Fix this with an update.
    Khushii21 likes this.
  2. Liehjan
    Marshmallow May 17, 2021
    Liehjan , May 17, 2021 :
    42-43°C SoC temperature isn't overheating... It's normal temps when doing something more intense.
  3. Khushii21
    Ice Cream Sandwich May 17, 2021
    Khushii21 , via OnePlus 7 , May 17, 2021 :
    Hey !Some tips:
    1. Use your phone on Battery Saver mode .
    2. Remove all the junk files and malware from your phone. It helps to some extent !
    3.Try to keep your brightness low
    4. Always close unused apps cause they're running in the background.
    5. You can turn on the airplane mode .
    Hope I was useful !
    MANAV1113 likes this.
  4. MANAV1113
    Cupcake May 18, 2021
    MANAV1113 , via OnePlus 7 , May 18, 2021 :
    Overheating, when compared to what it was like before the update. Although I play the game at low graphic settings. This ain't normal.
  5. MANAV1113
    Will try doing all those except the last one cause it's an online multiplayer. But thanks a lot. I hope for them to work.
  6. Liehjan
    Marshmallow May 18, 2021
    Liehjan , May 18, 2021 :
    It may be hotter than before, but the word "overheating" means the SoC is running at a temperature higher than it's designed thermal limit... What you need is better OS optimization that will happen in coming builds as always.
    Khushii21 and MANAV1113 like this.
  7. MANAV1113
    Thats helpful. They better fix this issue.
  8. A.Jeyasankar
    Eclair May 22, 2021
  9. Paradise_Sunil
    Eclair May 22, 2021
    Paradise_Sunil , via OnePlus 7 , May 22, 2021 :
    I have tried all those but no results
  10. Khushii21
    Ice Cream Sandwich May 22, 2021
  11. Paradise_Sunil
    Eclair May 22, 2021
    Yeah, i think so... But to be honest the performance of OP7 is getting worsen day by day
