Overheating while charging
  1. mradul5
    Gingerbread Sep 20, 2016
    mradul5 , Sep 20, 2016 :
    ..my phone has been running on paranoid rom for 2 months now And its having overheating issues while charging since last week or so.. I can't figure out the reason.. What could it be and how can it be solved.. Pls help.
  2. Mr. BG
    Community Hero 2020 Sep 20, 2016
    Mr. BG , Sep 20, 2016 :
    Charging with phone off or on?
    Edit: consider also asking this the Paranoid guys on Google+ or XDA forums.
    mradul5 and Gonzo01 like this.
  3. Dchrono
    Honeycomb Sep 20, 2016
    Dchrono , Sep 20, 2016 :
    PA is an amazing rom please don't interpret this otherwise but I too experienced this when I ran the rom. Heat is a killer so I didn't stick with it to troubleshoot the issue. I always keep a battery heat sensor on (klwp), if it goes above 40c I begin to worry. I recall reaching 46c on PA while charging and using the phone, otherwise it would be in the 39c range which was too high for my liking. I believe it was the kernel and suggest Arsenic kernel to resolve the issue.
    Temp shown on status bar
    mradul5 likes this.
  4. mradul5
    It heats up even when powered off..
    And it becomes unbearable when i use something heavy on proccessor while charging..
  5. mradul5
    Thanks.. I will wait for some time.. And then switch to oxygen os again
    Dchrono likes this.
  6. Mr. BG
    That's not good, I advise to go back to stock, if that doesn't work out it might already be too late for your hardware (battery etc). Remember rooting doesn't void warranty, but damage as a consequence of flashing alternative ROMs is not under warranty...
    mradul5 likes this.
  7. todmephis
    Donut Sep 21, 2016
    mradul5 likes this.
