2
Overnight battery drain via OnePlus 7
  1. G_Suhas_M_jUke
    Donut Sep 26, 2020
  2. Artemus.
    Nougat Sep 26, 2020
    Artemus. , Sep 26, 2020 :
    Possible solution: post battery graphs so we, as a community, can determine what the problem is. Showing is better than telling. You also can tell us what OOS version you're running.
    Gdsingh94 likes this.
  3. G_Suhas_M_jUke
    Donut Sep 26, 2020
    Moulichandu1316 likes this.
  4. rcaldejr , via OnePlus 7 Pro Nebula Blue , Sep 26, 2020 :
    I am having MONSTER battery drain throughout the day. It's getting bad, as I can no longer make it all the way through my day without needing a charge at some point.
    Here's a few screenshots of my current graph, as well as use time for the top apps. Please, can we get a fix. said:
    Running OOS Beta 18 for OP7P.
    1601101773861.jpg said:
  5. Artemus.
    Nougat Sep 26, 2020
    How often do you use Tidal?
  6. rcaldejr , via OnePlus 7 Pro Nebula Blue , Sep 26, 2020 :
    Everyday, but Tidal was not used as much as usual today. Tidal is having issues of their own they need to work out too.
    I usually average 3-4 hours of total use for Tidal in a day. Today was only 1.5 hours.
  7. Artemus.
    Nougat Sep 26, 2020
    Try using it less and see if it helps.
  8. F1589716878576
    Cupcake Sep 26, 2020
    F1589716878576 , Sep 26, 2020 :
    Many users has drain battery in last few days. Problem is Google Play Store.
    delete cache and data play store and install newest version from ex. Apkmirror.com ( now 22.0.18)
    Observe battery in next days.
    Its not only oneplus problem.
    yashvidrohi likes this.
  9. A1574444726162
    Donut Sep 27, 2020
  10. F1589716878576
    Cupcake Sep 27, 2020
    U1527917758122 likes this.
  11. CS2112
    Donut Sep 28, 2020
    CS2112 , via OnePlus Nord , Sep 28, 2020 :
    I have OnePlus Nord, from last 2-3 days the battery is draining fastest.
    How to avoid this. I have stop all backgrounds app running still it is draining.
    is this coz of new update.
  12. Artemus.
    Nougat Sep 28, 2020
  13. Karan9559
    Eclair Sep 28, 2020
    Karan9559 , via OnePlus 7 , Sep 28, 2020 :
    I'm having a similar issue with my oneplus 7 and the culprit is play store.
    Tried clearing the data and cache, that didn't make any difference on the drain.
  14. F1589716878576
    Cupcake Sep 30, 2020
  15. 1bhavin12001
    Gingerbread Oct 1, 2020
  16. G_Suhas_M_jUke
    Donut Oct 5, 2020
  17. O1587701878292
    Cupcake Oct 10, 2020
    O1587701878292 , Oct 10, 2020 :
    My overnight battery drain is taking 10-15%. Is it because of the update ,earlier it was 3-7%.Any solution..
  18. Artemus.
    Nougat Oct 10, 2020
    Artemus. , Oct 10, 2020 :
    Screenshots help.
  19. O1587701878292
