3
Overnight Battery Drain
  1. #21
    Rohit_vs_94 likes this.
  2. mustafarangeela
    Eclair Apr 21, 2021
  3. #23
  4. Rohit_vs_94 , via OnePlus 9 Pro Stellar Black , Apr 22, 2021 :
    I drained the battery to zero and charged it to 100% and kept over one hour after that and then used the phone also updated to the latest version [Had just got the update and updated before the battery drain to 0] and now it's actually much better. Now 5% drain overnight. Unlike 11% before. Then you for the answer it really helped😁😁
    MakB likes this.
  5. MakB
    Honeycomb Apr 22, 2021
    MakB , via OnePlus 9 , Apr 22, 2021 :
    Great.. Enjoy your phone dear. 👍
  6. #27
  7. Lucille
    Gingerbread Apr 23, 2021
  8. Ultradyong
    Gingerbread Apr 24, 2021
    Ultradyong , via OnePlus 9 Pro , Apr 24, 2021 :
    Did you try disabling intelligent network connection or dual-channal acceleration. Do it manually, as it might help save battery life or battery drain, download an app known as Kill apps to rid apps running in background or if interested purchase the app pro version from Google Play store.
  9. sunny1689gupta , via OnePlus 9 Pro , Apr 24, 2021 :
    The problem with OnePlus battery optimization is that the "Doze" doesn't activate quickly and when it does, it is not stable overnight.
    My recommendation: install a simple app by a great developer called "Naptime".
    It ensures that the Doze kicks in quicker. It DOESN'T REQUIRE ROOT. Just two adb command lines.
    This will give almost 0% battery drain,yes 0% overnight and you don't need to deactivate any useful wifi or bluetooth functions.
    Hope it helps enjoy.
    https://play.google.com/store/apps/details?id=com.franco.doze
