239
Oxygen 1.0.2 Release with Stagefright security patches
  1. DeltaSky
    Ice Cream Sandwich Aug 14, 2015
  2. deoliveiranv
    Honeycomb Aug 14, 2015
    zaklinacz likes this.
  3. bkbkjbb
    bkbkjbb , Aug 14, 2015 :
    Snakes can be very quick when they strike
    néonaloj likes this.
  4. bkbkjbb
    So do i....now
    :D
  5. Joyyy
    Jelly Bean Aug 14, 2015
    Joyyy , Aug 14, 2015 :
    .... Waited all this time for a new update on Oxygen OS with new improvements and features... And you just released a exploit fix? That's it? Seriously?.......
  6. Alecksander
    Alecksander , Aug 14, 2015 :
    Yes but not a public release.
  7. karthikigloo
    Froyo Aug 14, 2015
  8. scottrc
    Eclair Aug 14, 2015
    scottrc , Aug 14, 2015 :
    A fix which I think is now not working... http://www.itnews.com.au/News/40790...right-patch-leaves-android-users-at-risk.aspx
    There is now second patch as the first patch failed. Can OP confirm if this fix is the first patch or second? If it's the first then there is no point in anyone updating.
    Joyyy likes this.
  9. hrishi21007
  10. mohananpg
    Froyo Aug 14, 2015
    mohananpg , Aug 14, 2015 :
    Ah! Thanks a million
    Titokhan likes this.
  11. Espada04
  12. psx
    Gingerbread Aug 14, 2015
    psx , Aug 14, 2015 :
    Great to see OnePlus still supporting the OnePlus One like Nexus devices.
  13. Spliffman
    KitKat Aug 14, 2015
    Spliffman , Aug 14, 2015 :
    Thanks for the heads up
  14. Semmotorsports
    Eclair Aug 14, 2015
  15. kd0h
    Froyo Aug 14, 2015
    kd0h , Aug 14, 2015 :
    Trying to dirty flash- anyone else getting MD5 does not match?
    vinay.k.21 likes this.
  16. Me1256
    KitKat Aug 14, 2015
    Me1256 , Aug 14, 2015 :
    Well, we haven't seen an update in a few months, I was worrying we wouldn't see an update at all.
  17. lsamanl
    Eclair Aug 14, 2015
  18. armmani2001
    KitKat Aug 14, 2015
    armmani2001 , Aug 14, 2015 :
    Thats nice I should say!
  19. Me1256
    KitKat Aug 14, 2015
    Only if you flashed cm12.1. And my point was, that since cyanogen develops the updates, and other manufacturers are supposed to receive the same updates, and have not, the only common denominator is cyanogen, the one providing the updates.
  20. phonehog
    phonehog , Aug 14, 2015 :
    I am on CM11.44S also. Like mentioned before, you can't use this patch unless you switch ROM to Oxygen altogether.
    If you want to fix the CM version that will eventually come out later in the month, you will need to upgrade to the CM11.05Q version then to the CM12 & then you can get notify for the CM12.1 update later this month.
    nickwag likes this.
