239
Oxygen 1.0.2 Release with Stagefright security patches
  1. rswheaton
    Honeycomb Aug 14, 2015
    rswheaton , Aug 14, 2015 :
    Did I read this correctly? It appears that this will not fix the Stagefright issue? I believe that One Plus said they will be releasing another updated release???
    pbergonzi likes this.
  2. DeltaSky
    Ice Cream Sandwich Aug 14, 2015
    DeltaSky , Aug 14, 2015 :
    Thanks for the swift update.
    What about the users running Cyanogen OS... Earlier you stated that you have a little control over the OTA rollout for Cyngn so I think it's the right time.
  3. scottrc
    Eclair Aug 14, 2015
    scottrc , Aug 14, 2015 :
    I think they said they will do another update in 2 weeks time to address the latest issues of the stagefright bug.
  4. rswheaton
    Just found it...
    Helen said:
    It does not contain the new patches. We will try to push another patch next week.
    All our builds are certified :)
  5. johmss
    johmss , Aug 14, 2015 :
    Flashed via TWRP (almost couldn't start it) Factory reset, wiped cache amd Dalvik (?).
    searched for sotware updates, but din't find any ( =P )
    Runs smooth (like oxygen) but have to check if Google Services drains battery. Don't remember how to fix it though
  6. yassinelg
    Cupcake Aug 14, 2015
  7. DeltaSky
    @Helen
    Can we expect OTA's on Oxygen? For OPO...
    or just full zips like this ...
    BTW a request!
    Code:
    [OTA Changelog 5.0.2/1.0.3]
    MaxxAudio
    Dark Mode
    New bootanimation
  8. drdrjojo
    Gingerbread Aug 14, 2015
  9. mevicks
    mevicks , Aug 14, 2015 :
    Ditto. No use waiting here... Go to Xda Get a rom of your choice and bam. Already on resurrection remix here...
  10. fbnpirates
    fbnpirates , Aug 14, 2015 :
    woow. that's fast. Never settle really. 5555
  11. Capta1nZap
    Capta1nZap , Aug 14, 2015 :
    What is the changelog for this... let's say update ?
  12. yassinelg
    yassinelg , Aug 14, 2015 :
    Delete the md5 file and try again
  13. guijan12
    KitKat Aug 14, 2015
  14. pbergonzi
    KitKat Aug 14, 2015
  15. Deactivated User
    Aug 14, 2015
  16. pbergonzi
    KitKat Aug 14, 2015
    pbergonzi , Aug 14, 2015 :
    We had good reason, being ignored, I think.
  17. pbergonzi
    KitKat Aug 14, 2015
    I didn't wipe diddly, unless TWRP did some wiping automatically.
  18. rswheaton
    Im so confused??? This update does not fix the problem. Why is everyone installing it??? o_O
  19. kmagos
  20. pbergonzi
    KitKat Aug 14, 2015
    If you are confused, re-read the first post. This update has a fix for the Stagefright vulnerability that is in all of Android, and therefore the OxygenOS version of Android. It will make your phone more secure. If you've already flashed OxygenOS, it is HIGHLY recommended that you flash this to provide security to your phone.
