239
Oxygen 1.0.2 Release with Stagefright security patches
  1. hongphooey
    Honeycomb Aug 18, 2015
    hongphooey , Aug 18, 2015 :
    I'm also getting that error and its annoying as hell. I can't seem to figure it out.
    Steps I've taken so far have been:
    With TWRP
    Dirty flash-fail
    Clear cache and dalvik - fail
    Downloaded and installed update OxygenOS 1.0.1 - worked, but failed > 1.0.2
    Not sure what I'm doing wrong here.
    vinay.k.21 likes this.
  2. npalarpwar
    Cupcake Aug 18, 2015
  3. ruben8448
    Froyo Aug 18, 2015
    ruben8448 , Aug 18, 2015 :
    Oh, my bad haha. Either way, no one plus two. haha
  4. Me1256
    KitKat Aug 18, 2015
    Me1256 , Aug 18, 2015 :
    I think you can turn off md5 verification in the twrp settings.
    rarog likes this.
  5. Sean Hayde
    Gingerbread Aug 18, 2015
    Sean Hayde , Aug 18, 2015 :
    Are updates applied ota
  6. Bozso46
    Bozso46 , Aug 18, 2015 :
    Don't know much about the security issue, I always disable MMS on all my phones. Who uses MMS and why?
  7. Orya
  8. rarog
    Lollipop Assistant Head Moderator Aug 18, 2015
    rarog , Aug 18, 2015 :
    That's what I was going to say. I turn it always off as I never put the MD5 files besides the ROMs.
  9. tabishch
    Eclair Aug 18, 2015
  10. winstonsmith
    winstonsmith , Aug 18, 2015 :
    Delete the .md5...
    agarwal.amal likes this.
  11. pankajkundlia
    pankajkundlia , Aug 18, 2015 :
    Nice to see such big issue patch come so fast!
  12. Kruunkk
    Kruunkk , Aug 18, 2015 :
    Have TWRP ignore the MD5 and flash as normal.
  13. Kruunkk
    This!! A million times this!
  14. ASWIN RAJEEV
    ASWIN RAJEEV , Aug 18, 2015 :
    nice thanks
  15. sergiemiyagi
    sergiemiyagi , Aug 18, 2015 :
    When trying to flash it, it says 'MD5 does not match'.I have both the Oxygen Zip and MD5 files in the same folder. help?
  16. Berz
    Froyo Aug 18, 2015
    Berz , Aug 18, 2015 :
    Im just getting a oneplus one.
    any idea when the 5.1.1 is being rolled out ?
    and if the memory leak exists in 5.0.2 oxygen OS? because i'd hate to use the damn CM rom
  17. sameersmarti001
    sameersmarti001 , Aug 18, 2015 :
  18. lalitapat
    lalitapat , Aug 18, 2015 :
    Thanks for the response i deleted the MD5 file and it started to work
  19. VBE
    VBE , Aug 18, 2015 :
    That's great
  20. kkvasudevan
